588,658 active members*
4,981 visitors online*
Results 1 to 11 of 11
    Jul 2006
    19
    svo13 y and u improper v_ready off
    i have major problems, my heian has been down for 3 weeks now. i was told that it was the amp, we have changed it twice and still doing the same thing. the error is SV013 Y and U IMPROPER V_READY OFF. ANYONE HAVE SUGGESTIONS ON WHAT I SHOULD DO NOW!!!!!!!
    Dec 2003
    24222
    Sounds like a Fanuc? what make & model?
    Al.
    Albert E.
    Jul 2006
    19
    Fanuc Series 15-m
    Dec 2003
    24222
    What axis do you actually have?
    Al.
    Albert E.
    Jul 2006
    19
    x and z is not off but my ready light is also off.
    Nov 2006
    17
    check input voltages to drive on all 3 phases should be between 200-220.(BE CAREFULL )
    Not sure but drive may be detecting fault on a phase U ,may be on output, you could swap x and y drives if drive and motor the same to see if fault transfers .I will check with Fanuc uk in morning for you but cant reply til pm. Good Luck
    Nov 2006
    17
    Not much more info from Fanuc i'm afraid. They reckon could be main system,wiring or amp (pretty vague eh!) sorry!
    Jul 2006
    19
    we are checking wiring today and more fuses. thank you
    Dec 2003
    24222
    Do you have the maintenance procedure for checking SV013?
    Al.
    Albert E.
    Jul 2006
    19
    no maintenance procedure just standard checking.
    Jul 2006
    19
    on the problem that i had, i was sending my amp off to be rebuilt which did not work so i ordered a new one which cost about $5000 but now i am up and running. thanks to everyone.
