Thanks for the reply Tom.
Found the documentation for Kflop, in which it mentions power can be taken from a pc power supply:
https://dynomotion.com/Help/Schemati...ctorsKFLOP.htmThis connector is a standard PC-disk drive power connector which makes it easy to drive the board with an inexpensive PC power supply.
What do you recommend? I don't want to risk damaging the board.
I'll run power to my encoders from JP12 pins 33,34 and 35.
Does the Kflop / Kanalog have an enable / charge pump pin? Which can be attached to an emergency stop for example?
