587,997 active members*
1,782 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Gryphon - MX4660 - Mach 3 - Huanyang VFD and spindle
Results 1 to 11 of 11
    Apr 2013
    14
    I purchased a Gryphon CNC 4' x 8' kit about 9 months ago. I received it about 2 months ago, and finally have it all built, wired, and trying to run parts.
    I have Mach3 running to a UC100, to a Leadshine MX4660, all of which was provided as part of the kit.
    I added the Huanyang VFD and 2.2kw spindle.
    Problem 1: I can't get Mach3 to control the spindle, because the output on the 0-10v is always 8.8v, no matter what settings I try to change in Mach3. I am sure I have something set wrong, but I can't find a solid set of paramters for this machine.
    Problem 2: I set the VFD up with the paramters provided by another user here, who seems to be the only person to post a complete set of correct paramters. However, everytime my spindle ramps up, I get a EOCA alarm at around 80hz.
    I'd really like to get this machine running, as I have jobs lined up. This is my first built, other than 2 x-carves. I have been running commercial routers for over 10 years, and have 20 years of machining, so I am more of a programmer and operator than a builder.
    15362
    Re: Gryphon - MX4660 - Mach 3 - Huanyang VFD and spindle
    Quote Originally Posted by evilusions View Post
    Is your spindle 220v you may have used the wrong Parameters that was for another spindle
    As for speed control this could be the PWM output not the settings in Mach3
    Mactec54
    Apr 2013
    14
    Looks like i got your settings from another thread. These are what i used.
    Dec 2003
    24220
    I
    Have you looked at the Mach/VFD plug-ins in order to run the VFD via the RS485 link?
    I find it much better as far as opposed to setting up the 0-10v analogue.
    The one I prefer is the one by Sebastien, there are details on the Mach forum.
    Al.
    Albert E.
    15362
    Ok when you posted in the other thread, it look like you had used those parameters, the list you just posted I don't do it like that anymore as it was to confusing for some people with using one posting to cover all spindles
    Make sure these are set, if it still fails you will need to check the Cable from the VFD to Spindle that the connections are correct, next check the spindle plug with a meter
    The fault is saying you may have a short in your wiring, but also could be ramp up to speed it is drawing to much current
    Pin 1 to Pin 2
    Pin2 to Pin 3
    Pin 3 to Pin 1
    Pin 4 to Ground spindle body
    Pd006=15
    Pd007=20
    Pd008=220
    Pd010=10
    Pd141=220
    Mactec54
    Apr 2013
    14
    Looks like i have a short between pin 1 and 3, but only when the cable is plugged into the spindle. Does that mean a bad spindle?
    15362
    If the spindle checks out ok, without the cable, then it most likely is how the plug has been connected to the cable, there is not much room in those plugs, and the right wire size must be used this is the correct cable to use for your spindle size
    Check the cable by its self, this is where most problems are found
    CF6-15-04 you can get this cable from IGUS
    Attached Thumbnails Attached Thumbnails Chainflex CF6.pdf
    Mactec54
    Apr 2013
    14
    That's great because the igus cable carrier rep was due in anyways to quote me the carriers on this machine.
    Thanks,
    15362
    Thanks,
    This cable CF6-15-04 is there mid-range cable, and will work fine for you, they have more expensive cable per foot, than this that will do the same job as well it's number is
    CF35-15-04 TPE
    CF31-15-04 PVC
    https://www.igus.com/iPro/iPro_01_00....htm?c=US&l=en
    file:///D:/Chinese%20Spindles/Chainflex®%20CF35%20motor%20cable%20TPE.pdf
    file:///D:/Chinese%20Spindles/Chainflex®%20CF31%20motor%20cable%20PVC.pdf
    Mactec54
    Hello, I also have a gryphon, and trying to make upgrades to my machine. I will be installing a spindle soon, and would to know how your installation turn out. Currently I'm trying to install a z zero touch plate but cannot get it to work. I've try using pin 13 and 15, following the varies YouTube tutorials and other mx4660 threads on this site, but still no lucky. Does anyone here have any idea on how to install this. I'm using the preload Mach 3 profile "Gryphon V-3 Horizontal". Any help is greatly appreciated.
    Jun 2005
    Get rid of the uc100, use a db25 pin
    Cable. To a pc. Not a laptop. Also check the wiring.some of it on the mx4660 book is backwards.
    Check pump led. Todd
  1. MX4660 Speed Control for 2.2 KW huanyang vfd
    By Dekman in forum Leadshine
    Last Post: 06-27-2022, 10:10 PM
  2. Leadshine MX4660 Mach 3 Setting
    By gcnc588 in forum Leadshine
    Last Post: 12-18-2019, 04:27 AM
  3. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  4. Spindle Relay Control with Mach3 and MX4660
    By icecats in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2017, 12:29 PM
  5. Replies: 2
    Last Post: 12-31-2013, 04:33 PM
