Originally Posted by
maxspongebob
Goemon. Good question.
I always try to visualize the forces at work to get a better understanding of where things should go. The way my brain works might be interesting to some, silly to others, but here it is.
Imagine that there was a tray of mud on the surface of your router. Then imagine a stick in the mud that you use to mix it using your hands. If the mud is very thin, mixing is easy. If thick mud, then not so easy.
Now the analogy. The end of the stick in the mud is the cutter. One of your hands on the stick is the ball screw (can only move back and fourth) and one is the rail bearings (can only keep the stick straight). Hold the stick with the rail bearing hand at the end opposite to the mud. Put the ball screw hand in the middle of the stick then move the stick back and fourth through the mud. The closer the ball screw hand is to the mud, the easier it is to move and easier to keep the stick straight with the ball screw hand. Then imagine if the hands were reversed. Ball screw hand is at the opposite end of the stick from the mud and the rail hand is in the middle. In this configuration when you try to move the stick through the mud, you are increasing the amount of twist on the rail hand to move the stick.
The end result is that when the ball screw is between the cutter and the rail, you are reducing the amount of torsional force on the rail bearings depending on the distance between the cutter and the ball screw. Where the rail bearing is between the cutter and the ball screw, you are increasing the torsion on the bearing depending on the distance.
Granted, there are lots more forces at play here, but it always helps me to visualize the situation. The closer you can put the ball screw to the work and in line with the rail bearing, the better.
