587,997 active members*
1,721 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Power Mate- Model D Memory Card Problem(CRT MODEL)
Results 1 to 5 of 5
    Apr 2018
    3
    Hi everyone,
    This is my first message. How can i download or upload with memory card? Please tell me step by step.
    I use CRT/MDI. I dont have DLP/MDI.
    Dec 2017
    34
    Re: Power Mate- Model D Memory Card Problem(CRT MODEL)
    I'll try this from memory, and hope it's the same control I'm thinking of.
    After you put the memory card in the slot, push the program button.
    That should bring up card on a soft key.
    hit the soft key, and it will read the card and show you what is on it.
    Other things will come up on the soft keys now.
    Everything is numbered, so it asks you for the number, you can skip all the zeros and just type in 1,2.3........and then push the soft key for the number
    Then type in the program number you want to use and push the soft key for the O number.
    Then hit execute. That should work.
    http://www.heavymetalcnc.com
    Everything you need to know is in this manual.
    Attached Files Attached Files
    Apr 2018
    3
    Thanks, bro.I will try today.But which button i will push ??? And then will i go to card?
    Apr 2018
    3
Name:	CRT PANEL.jpg
    crt like that
