587,349 active members*
3,601 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > My router went today on my old DIY table need advise
Page 9 of 9 789
Results 161 to 174 of 174
  1. #161
    Jun 2017
    369
    Re: My router went today on my old DIY table need advise
    I was doing some research and found this on another forum, does it sound right?
    To calculate RPM use this formula, in which you will have to find RPM's when you have Hz.
    1 RPM = 0.01666666667 Hz
    Formula: 0.01666666667 × RPM = Hz
    On our VFD if you select the >> button about 3-4 times, it will change from Hz, A, or ROTT.
    When the LED's are lit on Power, FOR, and ROTT, you should be able to see the RPM the spindle is running at, our maximum setting for these spindles is 400Hz / 24000 RPM.
    I also found a post saying there is an order that you need to set the programs in the vfd? I cannot get desk cnc to allow me to change rpm's but it will allow me to change rpm through the perimeter on the vfd. I assumed it was DeskCNC being antiquated but maybe it's a setting I've got wrong, any advise?
  2. #162
    Jan 2018
    29
    Quote Originally Posted by Gary-Wiant View Post
    Gary, for a 2-pole motor (which these spindles normally are), your equation is technically right, but it’s much easier to times and divide by 60 (the inverse of .016667).
    Hz x 60 = RPM; RPM / 60 = Hz
    Note this only works for 2 pole motors. Some spindles are 4-pole and for those you would use 30 instead of 60 in the equation.
    As far as the VFD settings, I can’t offer much help there.
    Sent from my iPad using Tapatalk
  3. #163
    Feb 2008
    482
    just confirm your on screen rpm is roughly the same as vfd frequency- then use on screen display.
    i prefer to monitor current on the vfd- it gives a great insight when your tools are going blunt or your working it too hard.
    so much to learn, so much to pass on.
  4. #164
    Jun 2017
    369
    Brokenhorn - thank you, I'll make sure we have the vfd set to 2 pole and use the formula.
    Battwell - I'm learning a lot but here is where I'm going to let my newbe show. How do I monitor current on/of the VFD?
    I cannot get DeskCNC to adjust the rpm. It will show a simulated rpm based on the spindle setting ( it is just a slider ) the cadcamcadcam.com instructions for the 0-10 card I purchased, say to move the slider all the way to the right on deskCNC which shows 24000 but since I cannot get the spindle to run from DeskCNC the slider doesn't really do anything.
    This part will be from memory so the program #'s may not be correct but When setting up the vfd we had changed the program 1 & 2 from 1 to 0 to allow control from the software but it kept changing back to 1 which meant manual ( through the vfd ) we assumed it was DeskCNC being old so we left it alone.
    I do think we left the poles set the default of 4 because the spindle late didn't show anything. Thank God we only ran it to check to make sure it worked & the direction is correct so hopefully we didn't cause any damage.
    This is the post I found on this forum that mentions the order to setup the programs. This is also from 2010 so I'm not sure if the vfd program has changed or not.
    1. I drafed the wire pictp
    ure. Please see from the link: http://www.jinlantrade.com/Stock%20files/0008.jpg
    2. You can see download the inverter manual from web link:
    404 Not Found
    3. I just tell you how to set up VFD as following
    Firstly, adjust the PD013 to 8 (set the setting to factory setting)
    Secondly, adjust the PD005 to 400
    Thirdly, adjust the PD004 to 400
    Finally, adjust the PD003 to 400
    Finally, adjust the PD144 to 3000
    Note: you should set PD013, PD005, PD004,PD003, PD144 in order. It mean you should firstly set PD013, then PD005, then PD004, then set PD003, finally set PD144.
    Note: after you set the all above parameter, then please recheck the PD005, PD004, PD003 value is 400 or not to confirmed that you already set it. (note: please do not check the PD013, or all the setting will go to factory setting)
    The reason we let you recheck is that if you do not set it at 400, then when you run the spindle motor, the spindle motor will be over-current, then the spindle will very hot and then within 5 minutes, it will broken.
    Thank you
  5. #165
    35538
    The order you set parameters shouldn't make any difference.
    What do you have for parameters P001 and P002. You probably have the VFD set to manual mode.
  6. #166
    Jun 2017
    369
    It is set to manual (I think 1) but when I change it to the other # (0 ?) The VFD changes back to 1.
    I'll check later today & let you know.
  7. #167
    Jun 2017
    369
    These are the only program changes we made
    Program 1 is set to 1
    Program 2 is set to 1
    Program 3 is set to 400
    Program 4 is set to 400
    Program 5 is set to 400
    Program 8 is set to 220
    Program 14 is set to 2
    Program 15 is set to 2
    Program 23 is set to 1
    Program 44 is set to 2
    Program 45 is set to 3
    Program 141 is set to 220
    Program 142 is set to 6
    Program 143 is set to 2
    Program 144 will only go up to 9999 not 24,000
    I tried the >> Button trick to show the RPM'S and it Max's out at 11520
    If you see anything I have set wrong please let me know.
  8. #168
    Jun 2017
    369
    Do these changes look correct?
  9. #169
    35538
    PD144 should be set to 3000.
    There's a jumper in the VFD that needs to be set to terminals 1-2 for external control. Make sure that it is.
    Do you have PD072 = 400?
  10. #170
    Jun 2017
    369
    Thanks I'll check Monday when I get back to the shop
  11. #171
    Jun 2017
    369
    I wrote up a long post early this morning but I don't see it now.
    I checked pd 0072 and it was on 400.
    I changed pd 0144 to 3000
    I changed the jumper to 1-2
    It is working "occasionally" now through DeskCNC but I cannot figure out what I'm doing that makes the spindle to turn on. Impress run on the vfd the toggle the CCW ON / OFF a couple times & it will start up. I'm sure it is probably operator error but it would be nice to figure out the key to getting it to start consistently.
    The good news is I can adjust the RPMs but moving the spindle slider on DeskCNC, but the RPM's values on DeskCNC & the VFD don't match exactly.
  12. #172
    Jun 2017
    369
    Anyone?
  13. #173
    35538
    You need to make sure that DeskCNC is outputting the proper voltage, and doing what it should be to start and stop the spindle.
    I've never used it, so can't really offer any help.
    Unfortunately, there probably are very few people using it. I thought they stopped selling it 10 years ago.
  14. #174
    Jun 2017
    369
    Ok thanks I was afraid that was going to be the issue.
Page 9 of 9 789
  1. Need advise for retrofitting old XY table
    By markgering in forum DIY CNC Router Table Machines
    Last Post: 08-04-2018, 02:29 PM
  2. Started building new 5 X 10 table today
    By millman52 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-09-2016, 01:19 AM
  3. What $15k plasma table would you buy? Would you buy yours again today?
    By metriccar in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-12-2013, 11:52 AM
  4. $700 dollar 6'x12' cnc router table would you buy this?!?! advise..
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 04-05-2010, 03:48 PM
  5. Need advise on building a 4 axis 1.5m x 2.5m Router table...
    By ryanvu in forum DIY CNC Router Table Machines
    Last Post: 06-17-2009, 05:44 AM
