588,124 active members*
4,842 visitors online*
Results 1 to 6 of 6
    Apr 2018
    45
    Feature request
    I love Planet CNC TNG so far in my evaluation and I'm wondering if Planet CNC can comment on the following feature requests.
    1. Ability to resize the axis DROs.
    2. Ability to change the location of the Run, Stop, pause, and Estop buttons.
    3. More time readouts...Program est. Run time and
    Run time with ability to clear or reset.
    4. Cutter compensation. I tested with the old version, seemed to work ok but it was not calculating the tool diameter correctly.
    5. Jog mode buttons. Ability to set the jog mode for step distance.
    I is a significant investment to switch my machine to a new control so I'm looking for some indication on where the software is headed so I can fully commit to switching.
    Thanks,
    Fred
    Mar 2017
    1340
    Re: Feature request
    1, 2 UI enhancement and customization is planned, however we want to do everything related to g-code and machine operation first.
    3. Time readouts are problematic. There is no good way to calculate time except in simple cases. You can add "percent complete" value to your parameter tabs.
    4. Cutter compensation in old version works correctly. However it requires correct lead-in move and is more or less useless. We plan to make useful cutter compensation routines. It is one of our top priorities.
    5. I do not understand this request.
    Apr 2018
    45
    Quote Originally Posted by PlanetCNC View Post
    I may be overlooking this, I was looking to find a way to be able to toggle the step distance while jogging, for example I would select single step of .001 in. Or select .010 in if desired. I hope this makes sense.
    Apr 2018
    45
    Quote Originally Posted by yar20 View Post
    Also, is there any plans to add naming of inputs and outputs.
    It would be nice to be able to assign a name and then the name could be shown as a hint when viewing the i/o tab.
    Mar 2017
    1340
    Re: Feature request
    Sure, you can configure Step jog value, you do that in settings under: File/Settings/Control/Jogging/Step Distance -> insert desired value
    Apr 2018
    45
    Ok, but I was looking to be able to select the jog mode much like when using a handwheel. I see now this is not currently available. Any plans to implement this?
  1. Feature request - ref THD
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 04-07-2013, 02:49 PM
  2. Feature request
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-24-2013, 05:44 AM
  3. Feature Request
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 07-03-2008, 01:56 AM
  4. Request DNC feature
    By single phase in forum NCPlot G-Code editor / backplotter
    Last Post: 12-14-2007, 04:04 AM
