588,442 active members*
5,267 visitors online*
Page 46 of 51 364445464748
Results 901 to 920 of 1007
  1. #901
    May 2012
    93
    Re: DIY- CNC Embroidery Machine
    Hi Marquino ( and other with similar questions),
    CNC Embroidery machine was a project with the idea to use G-code ( typical language for a CNC machine) for embroidery machine.
    Like I said, this was an idea and never became functional software ( I can tell this, because I helped a lot in this project). So - for you and others, the answer is - there is not a lot of help with this thread.
    Maybe Hubordix idea can do something.
  2. #902
    Nov 2009
    8
    Hello friends!
    I started to challenge the original Zangs embroidery machine,
    I inserted a stepper motor nema 23 and driven it with Mach 3 and Khalid's program for gcode.
    I came to the problem with z axis, so I need the g code which I see generated with version 2.4.4 and this version can not find anywhere to download.
    Get in the way
    G0 X12 Y15 Z10
    G0 Z20
    G0 X12 Y16 Z30
    and I need a code
    G0 X12 Y15
    G0 Z10
    G0 X13 Y16
    G0 Z20
    so I would like to ask you how you can help us to solve this problem so that the machine can function normally.
    Thank you in advance!
    Photos are in the attachment.
    Attachment 379140
  3. #903
    Jul 2011
    37
    If the code was open sourced, the community could join together and make this work.
  4. #904
    Jun 2015
    7
    Hello Kuki21 my name is Jose and i´m form Cuba.
    I have been reading all post and just finished.
    I do not understand very well what is your problem.
    If you want to download version 2.4.4, you can do it on page 33 of this thread.
    Greetings.
  5. #905
    Jun 2015
    7
    Hello everyone.
    After reading the whole thread it is not clear to me some things:
    1- Apparently the machine did not work, but I have seen videos of Kalid and Rene that sew in an acceptable way.
    If the problem is speed at least I do not care, so with 150 SPM and good job completion, I'm happy.
    2- I do not want to use servomotors mainly because I do not have it and it is difficult for me to get it. Anyway I did not understand at all that to increase from 10 in 10 that began to use from the entry of Kiefer. (I do not have much knowledge of servomotors)
    In short, if someone could tell me why, after so much effort and work, the cnc embroiderer could not be made.
    Greetings to all.
  6. #906
    Apr 2006
    3498
    satovey, i can make the code open source but people will take my brain..i am a poor coder with no comments in the code...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  7. #907
    Jul 2011
    37
    Quote Originally Posted by Khalid View Post
    "take my brain", do you mean criticize?
    I get the no comments issue, I wrote over 2000 lines of code for a website and then one day I decided I wanted to make some mods. Only problem was I didn't comment the code so I couldn't remember what did what and had to go through and figure out what I did. I started commenting my code after that.
    If you want to make it open source; don't be concerned with people criticizing you or your code. Even the best get criticized, they just choose to not care about the criticism unless it is coming from someone they respect as a coder.
    Those who are interested in maturing your code will be the ones who work on it and will likely add commenting where they make mods..
    In the end, Open Sourcing your code and what licensing, whether GPL, LGPL or other, is entirely up to you.
    The two primary platforms mostly used for open source projects these days that I'm aware of are: github.com and sourceforge.net though there are others depending on what tools you used to create your projects.
    Take care.
  8. #908
    Jun 2015
    7
    Hello Khalid, first of all congratulations on your work, it is impressive.
    I have made simulations in my cnc and have achieved speeds of just over 200 SPM in version 2.4.8 assuming that each turn of the z axis moves in the DRO 2 units, therefore half a turn 1. For me that speed is fine , however I have not yet decided to build the embroiderer because I do not understand why it did not work what you were doing (I must be missing something). If you could spend 5 minutes of your time explaining, I would appreciate it.
    Greetings from CUBA. Joseph.
  9. #909
    Sep 2016
    8
  10. #910
    Jun 2016
    Thank you for your clarification kiefer, I have been able to contact Mr. Hubordix and he has given me some alternatives based on microcontrollers and Arduino.
  11. #911
    Apr 2014
    Hi all members may I get the final prototype of this embroidery machine to built one?
    Mujahid Shah
    Sent from my TA-1021 using Tapatalk
    Using Tapatalk
  12. #912
    Sep 2016
    8
    helllo
    DIY cnc hardware siemen s7 1200 software visual basic
    https://www.youtube.com/watch?v=vSmD0Vp173k
  13. #913
    Dec 2016
    ello Khalid
    You did not answer my last message! my question was she stupid?
    Since I changed the sewing machine, but my problem is always the same.
    So I ask you again humbly (being zero in programming) if it was possible that you leave free the incrementation value of "Z" for example for me, with my new machine, a half cycle is worth "0.575" and therefore the cycle complete "1.150". I do not see any other solution to my problem. Your program is already great, you did a great job. Thank you
    cordially
    Phil
  14. #914
    Jan 2016
    how to adjust the speed of sewing machine motor. with the x and y axis motors
  15. #915
    Sep 2016
    8
    distancex=donne
    distancey=donne
    speed of sewing/3=speedxy(
    =donne)
    speedxy=
    distance/timer
    timerx=temery =timer
    distance=sqrt(pow(distancex)+pow(distancey))
    timer=distance/speedxy
    speedx=distancex/timer
    speedy=distancey/timer
  16. #916
    Sep 2016
    8
    Quote Originally Posted by issamabaoui View Post
    distancex=donne
    distancey=donne
    =donne)
    speedxy=
    distance/timer
  17. #917
    May 2018
    8
    Re: Embroidery Gcode Generator V2.4.3
    g code generator cannot install for win 7 32bit
    please help me on this
  18. #918
    May 2018
    8
    hi
    i am new to this
    i like to make an embroidery machine
    can you give me details on the
    and the g code generator
    etc
    thanks
    Mewan
    Sri Lanka
  19. #919
    May 2018
    8
    hi Khalid
    i am new to this
    i have an idea to make a embroidery machine as a project.
    can you please help me on this?
    also i do not have the gcode generator software too
    thanks
    Mewan
    SriLanka
  20. #920
    May 2018
    8
    this file is not working for windows 7 32bit?
    can i know why?
    any way thanks for sharingyour valuables with us
    Mewan
    Srilanka
  1. Embroidery machines
    By Karl_T in forum CamSoft Products
    Last Post: 06-03-2016, 06:54 PM
  2. DIY Embroidery
    By infomatrix in forum DIY CNC Router Table Machines
    Last Post: 06-22-2013, 09:46 AM
  3. Replies: 1
    Last Post: 07-06-2010, 08:48 AM
