587,263 active members*
3,377 visitors online*
Results 1 to 3 of 3
    Mar 2008
    13
    Linear Encoder Maho600
    I all, I have a MAHO MH600E cnc 432, but no can move the x axis, this say Alarm X02: (Alarm measuring system fault), i suspect what is the encoder model AE LS 403 Heidenhain.
    Seeing the datasheet this have 1Vpp power suply of 5v, resolution is my doubt say 1um/0.005um, if anyone knew which of these two is the correct.
    other data is Grating Period 20um, and System Accuracy Grade of +-5um, here is other doubt, the diference between resolution and accuracy, why is the difference so much?
    I thought that the precision should be less than the resolution.
    This alarm refers to an encoder problem?, should I change this?
    Renato
    Feb 2008
    644
    Re: Linear Encoder Maho600
    Other than the .005 um, those numbers make sense: a 20 um pitch scale with a 20 X interpolator will provide 1um resolution and the scale is rated +-5 um/meter accuracy
    Mar 2008
    13
    OK thanks, refer a 5um/meter, it is ok.
    Renato
  1. Replies: 3
    Last Post: 03-13-2017, 04:39 PM
  2. HOW TO CHANGE ACTIVE ENCODER FROM LINEAR SCALE TO MOTOR ENCODER IN SIEMENS 840D.
    By sandeepmb123 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-02-2014, 08:05 PM
  3. Linear encoder
    By nik_ig_an in forum Fanuc
    Last Post: 12-11-2012, 10:55 AM
  4. linear encoder
    By valenti in forum CNC Machine Related Electronics
    Last Post: 08-24-2010, 05:23 PM
