587,558 active members*
3,738 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese spindle and VFD
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    ericks Guest
    Re: Chinese spindle and VFD
    Your tester should be on the ohm scale....leads in com and ohm/omega. You going to test for resistance
  2. #22
    ericks Guest
    What are the cable/wire colours to your spindle motor......the ones you had connected to U/V/W??
  3. #23
    Nov 2011
    51
    Quote Originally Posted by ericks View Post
    I was called into work shortly after I woke so its going to be a while before I can perform the test. It will be later today but I will do as you have instructed and update the thread with the results
  4. #24
    Nov 2012
    1272
    My guess is that your motor has a short between the windings and the frame. Easy enough to check with an ohmmeter as per Ericks' advice.
  5. #25
    15362
    Quote Originally Posted by KidKhaos View Post
    KidKhanos
    It is good that you did a Video, to try and help, but what you are showing is an Electrical code violation, I would suggest that you either change your wiring and do a new Video as this is a Bad example of how to wire anything like this
    You can not use a Neutral wire ( White wire ) as a Power wire for 240v NA, the Ground also ( PE ) can only be Green or Green / Yellow you can not use any other colored wires for these connections, your Grounding appears to be incorrect also
    You can use the White wire, only if you cover it with Black or red shrink sleeves / tubing or tape at both ends of the cable, your Grounds you have to change, or some how cover them also with the correct color
    Mactec54
  6. #26
    15362
    Quote Originally Posted by msdeltaguy View Post
    Thanks for the video but I have all that correct so far.
    Not if you wired it like he has in the Video, but hopefully you did it correct
    There is only 2 things that could be giving you a shock like you have experienced
    With your meter check the pins in your spindle
    Pin 1 to 2=
    Pin 2 to 3=
    Pin 3 to 1=
    And Pin 4 to Ground ( spindle Body ) this most likely is not connected inside the spindle, and is common with these spindles, to fix this you remove the top cover of the spindle and connect the 4th pin like the photo below
    Blow the water out before you remove the top if your spindle is water cooled
    The next thing to check is the wires in the plug that you connected and make sure there are nothing that can touch between pins
    Mactec54
  7. #27
    ericks Guest
    No worries......a was also busy at work, talk later
  8. #28
    Nov 2011
    51
    Pin 1 to 2=
    Pin 2 to 3=
    Pin 3 to 1=
    So put my Fluke in Ohms and test pin to pin like you have suggested then report back the results?
  9. #29
    Nov 2011
    51
    Pin 1 to 2=
    Pin 2 to 3=
    Pin 3 to 1=
    When i put my meter to measure Ohms im getting a constant reading of 1.7 between the pins you have asked me to measure across. Here is a picture with my cap off the spindle. absolutely no ground wire.Click image for larger version.
  10. #30
    ericks Guest
    So you have now confirmed that all three windings are okay. Now test between the spindle motor frame and any of the three pins 1/2/3 and report the reading........note not on the cap you removed, measure the main frame of the motor to one of those pins
  11. #31
    15362
    1.4 to 1.7 is a good number
    Ground Missing !! this is normal for most of these spindles as they do not use a Ground in China, this helps with population control
    So you must attach a Ground like I showed in the Photo, also make sure the cap and the body of the spindle are metal to Metal not paint or gunk on the faces this will make sure you have a good Ground,
    The Ground wire also can be attached to the screws that hold the Bearing cover ( next level down in the spindle body ) this can be a better more direct connection than the cap, and the cap would then not need to be cleaned up
    Mactec54
Page 2 of 2 12
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Chinese atc spindle
    By Jon.N.CNC in forum Spindles / VFD
    Last Post: 08-14-2017, 05:36 AM
  3. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  4. Chinese Spindle
    By paragon61 in forum Machinery Manuals / Brochures
    Last Post: 08-18-2015, 01:23 AM
  5. VFD for .8kW chinese spindle
    By _AR_ in forum Phase Converters
    Last Post: 01-22-2013, 08:26 PM
