587,529 active members*
3,353 visitors online*
Results 1 to 2 of 2
    Smallest CNC BT40 bit for cutting porcelain?
    Hi All!
    New member, first post.
    I'm in the tiling industry, looking to get into fabrication, and purchase a second-hand "helios zeus" CNC.
    Zeus - 3-axis CNC
    Does anyone know the THINNEST BT40 bit i can get to cut 12mm porcelain??
    (ive emailed the manufactorer, no answer)
    Cheers
    Jun 2010
    4262
    Re: Smallest CNC BT40 bit for cutting porcelain?
    Sorry, but your question does not make a real lot of sense - hence maybe the lack of a reply.
    BT40 is an interface between the spindle and the holder for the cutter. You can probably put anything from 0.5 mm diameter to 50 mm in a BT40 spindle.
    Now, what is the thinnest cutter you can get for 12 mm porcelain? An open-ended Q! I would think you should be able to get 5 m carbide cutters with a DoC >12 mm. How long would that cutter last? That really depends on RPM and cost of cutter! Cheap=>short. Alternately you could use a diamond cutter - WITH WATER. They are available with a good DoC, but ramp them in! I use diamond on basalt and granite.
    Cheers
    Roger
  1. Replies: 1
    Last Post: 08-14-2017, 02:13 PM
  2. Smallest sino water jet cutting machine SN1020 price
    By Sino-waterjet in forum News Announcements
    Last Post: 12-11-2013, 10:44 AM
  3. smallest cnc router CR2030 for Plywood cutting
    By SPC-laser in forum News Announcements
    Last Post: 01-22-2013, 03:41 AM
  4. Replies: 6
    Last Post: 05-11-2010, 09:07 PM
  5. (Laser) Machining Porcelain
    By Zathras in forum Glass, Plastic and Stone
    Last Post: 12-05-2007, 07:23 AM
