Re: Low speed spindle motor / gearbox selection
Originally Posted by
ZeroBacklash
I need at least a 2.2kW motor here. I need to drive this not as a spindle but as an axis because I need position control. The motor will be running continuosly at 5 to 10 rpm.
You describe two different conditions here. A 3 phase motor / VFD combination would work fine for continuous operation, but for position control you would need a servo or stepper.
If you geared down any standard 3 phase motor with a 150:1 gearbox it would get you into the RPM range you need with enough torque to twist about anything into a pretzel. You say you need a 2.2KW motor, more importantly what torque do you need? A 2.2KW motor geared down 150:1 would output more torque than my Diesel truck engine is rated at.
My questions are:
1. Is a AC motor + gearbox + VFD + encoder a good fit for this application. I mean what would be the min, max speeds I can safely run the motor without overheating issues.
2. What about dc or ac servo motor or even a bldc motor.Are these well suited for low rpms / high torque. Or do I even need a gearbox for these too.
Thanks in advance.
Again if you need positioning then a servo would be best option. Most servos will output near 100% torque at 0 RPM with a pretty flat torque curve through the RPM range.
Jim Dawson
Sandy, Oregon, USA
