587,999 active members*
4,147 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 24v 10A MPJA transformer winding question
Results 1 to 7 of 7
    Nov 2006
    10
    I bought the 24v 10A transformer that MPJA offers. Unfortunately the label on top has me confused about the windings and consequently how I should hook this up to 120v to get 24v out.
    Should I hook the primaries up in parallel (reds together and blacks together) or in series (red input, red and black connected together, black input)? What about the secondaries?
    I've attached a picture of the winding diagram and the primary and secondary leads.
    Thanks for any help.
    Aug 2006
    2758
    Primaries in parallel, Red-Red and Black-Black, secondaries output from Blue to Blue (24 Volt), leave the Yellow wire open
    Aug 2004
    2849
    Is that what you want 24VAC??
    Jul 2005
    76
    Kreutz is correct.
    Funny you should show this, I just set up a PS with this transformer a week or two ago. I got the cap from Digikey, and the H-bridge from EBay, I get 37V when all is said and done.
    Aug 2004
    2849
    24VAC X 1.414 = 33.96 VAC....without a load 37 VDC should be expected....all the voltages are specified at a particular load. By H-bridge....are you talking about a full wave bridge rectifier?
    Jul 2005
    76
    Right - too much CNC - got confused there.
    Nov 2006
    10
    Quote Originally Posted by ViperTX View Post
    From the transformer, yes. I understand that this will change after it's changed to DC, but I'm expecting that.
