588,582 active members*
12,409 visitors online*
Page 47 of 51 374546474849
Results 921 to 940 of 1007
  1. #921
    Apr 2006
    3498
    Re: DIY- CNC Embroidery Machine
    Considering the Hassle with present control system like Mach3.. I am shifting toward SD card based system with custom control.. Also looking for to control the rotation wheel with Servo. I think we will get industrial stitch speed on this. For all the guys who want to change in Zaxis values, please for time being you use Notepad to change manually or make a macro to post process your own value. I will definetly touch the SOFTWARE once i start working on hardware stuff...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  2. #922
    Oct 2005
    255
    Quote Originally Posted by Khalid View Post
    Have a look at this board. It has breakouts for step/dir to gecko's etc
    https://www.aliexpress.com/item/3D-P...E&gclsrc=aw.ds
    and smoothieboard [Smoothieware]
    Keep an eye on the g and M code limitation. is net workable.
    There is also some work on BLDC motors
    https://odriverobotics.com/
    good luck Khalid.
    Paul
  3. #923
    Apr 2006
    3498
    Thanks,
    The project achieved its milestone for embroidery but the number of stitches per minute is too less. Our main goal should be to achieve commercial stitches/time.
    Yesterday i was thinking on how to program the microcontroller that can get G&M code and transfer to hardware for their rapid function. I mean high speed stitching speed..
    1- 1st line of attack would be to add a simple optocoupler and a special encoder disc that will measure when the needle going inside the hoop and coming out. I will use interrupt function in the microcontroller
    2- SIMPLE CONDITION: You run the wheel motor to its maximum speed and just pause the X-Y at the location when the needle just start entering and until it comes out. This approach will be good for small length stitches but not work well for Jump Stitches (May be when jump stitch comes we stop the wheel and make sure the needle is up ).
    3- COMPLEX PROGRAMMING: To get the variable stitch length we should control the Wheel motor using PWM . We will 1st calculate the length of stitch and then adjust PWM of wheel motor and slow/fast it so that almost accurate stitch length achieved. For this We may have various approach. As i am going to do programming of microcontroller from scratch so all of community feedback will help me great.
    WE MUST COMPLETE THIS PROJECT AS EARLY AS POSSIBLE FOR FAST STITCHING.
  4. #924
    Apr 2006
    3498
    I also saw that many of us using Leadscrew for XY axis.. If we have to use Leadscrew that must be of multiple start. I will build my XY table with small NEMA17 motors and use belt. The other thing is that we are using G01 for moving X-Y axes table, instead we must use G00.
  5. #925
    May 2018
    8
    for the 2nd , no need to stop the motor we can make the length stitches in to few more stitches according to the jump length.
    this will do the eork
  6. #926
    May 2018
    8
    please help me to download embroidery gcode generator
  7. #927
    May 2018
    8
    i download this
    but cannot install this
    i tried in win 7 32bit
  8. #928
    Apr 2006
    3498
    Success with the servo motor:
    Attached Thumbnails Attached Thumbnails 34188163_10212489659825357_6118089627917090816_n.jpg   34131425_10212493023389444_7122090211051307008_n.jpg
  9. #929
    May 2018
    Re: Embroidery Gcode Generator V2.4.3
    Good evening,
    I thank you for all the work you did, it works perfectly.
    BUT I still have a problem that I do not know how to solve I do not have the decimal in the Gcode.
    I call you to find out if there is a solution?
    I thank you in advance
    "sorry for English (google translation)"
  10. #930
    Apr 2006
    3498
    Printale, you have to do some settings in the MICROSOFT WINDOWS, i think you are using "," in place of decimals...
    https://answers.microsoft.com/en-us/...f-6ca8afa5025a
  11. #931
    May 2018
    thank you Khalid,
    actually it corrects the problem.
    I am running Windows 10 your program works perfectly well.
    for french people who could have the same problem:
    link i have use: here
    THX; after correction
    PS: I'm also working on the integration of a servomotor on z
  12. #932
    Lightbulb Re: DIY- CNC Embroidery Machine
    grandes aportes
  13. #933
    Apr 2006
    3498
    Gracias
  14. #934
    Aug 2009
    56
    If someone have difficulties to find installation files, post number 852 on this thread might help https://www.cnczone.com/forums/cnc-w...ml#post1978278 It seems I can start this program on windows 10 64bit. Now can someone help and poke me to right direction, what program is recommend to make .dts files? I have a lot of experience using GRBL (arduino based Gcode stuff) and thinking this might work on it. But before doing anything, software bath must be checked carefully trough.
  15. #935
    Apr 2006
    3498
    You can make DST files in many Free softwares available on internet. I like:
    SophieSew Embroidery Software By Carlos Mandell
  16. #936
    Aug 2009
    56
    Thanks, it is not that easy to find suitable software, only thing I could find is https://inkscape.org/en/~wwderw/%E2%...dery-extension inkscape extension. This works, but .DST output seems to be broken currently, this can be avoided with .txt output and little bit of tinkering. Ok, let see how SophieSews.
  17. #937
    Aug 2009
    56
    Seems like my contraption is going to be belt driven, super simple, easy to make and 50% already done. I´m hoping to make some video or something when all comes together. But still need sewing machine, so is there anything special about it, any general purpose sewing machine will do? As long as it is fully working order, of course motor needs to be replaced to suit this purpose. But just about anything will do?
  18. #938
    Apr 2006
    3498
    James,
    Yes any General Low cost sewing machine in working order should work. I am also thinking of using Belt drive and Arduino-GRBL combination..
  19. #939
    Aug 2009
    56
    Attachment 400002
    Not sure should I call this progress, but at least something visible happened
    3D printing last piece ATM, I hope my pile of important/awesome pieces hold enough bits and bops to cook something up.
  20. #940
    Nov 2014
    37
    Hi....
    interesting thread for many years ,
    Has anyone built an embroidery machine to do logos on baseball caps ?
  1. Embroidery machines
    By Karl_T in forum CamSoft Products
    Last Post: 06-03-2016, 06:54 PM
  2. DIY Embroidery
    By infomatrix in forum DIY CNC Router Table Machines
    Last Post: 06-22-2013, 09:46 AM
  3. Replies: 1
    Last Post: 07-06-2010, 08:48 AM
