587,675 active members*
3,897 visitors online*
Results 1 to 6 of 6
    May 2010
    327
    Pathpilot USB port issues
    Circa 2013 controller that I upgraded to Pathpilot a couple years back. Recently have started having issues with the USB ports on the back of the computer. Initially I thought it was the touchscreen going south so took that out of the loop. Now have noticed that even the jog shuttle will stop working and sometimes work if I unplug/replug the connector and/or kind of wiggle the ports.
    I've disassembled the computer and nothing really looks incorrect, ports feel like they're still solid onto the board.
    So, looking for suggestions to buy new board or build a new smaller format controller that will accept the Mesa card. I use an SSD and never use the optical drive. Would love something 1/3rd the size.
    Also open to suggestions on other items to check. Power supply going south possibly? Might I get away with a powered external USB hub? Is it just a matter of time before the box goes kaputt?
    WW
    Aug 2014
    257
    Re: Pathpilot USB port issues
    Quote Originally Posted by wildwhl View Post
    So, looking for suggestions to buy new board or build a new smaller format controller that will accept the Mesa card.WW
    Yeah I wanted a much smaller computer that I could mount with my monitor & keyboard. You can read here: New Controller For MY PCNC 1100 what I did.
    This is much more computer than PP needs but I also run the desktop and other applications where the extra CPU power & RAM come in handy.
    Nov 2012
    591
    Could be oxide on the fingers on the USB connectors. Most USB connectors are fairly cheaply made and aren't rated for long life or many duty cycles.
    You might try with some flux or some contact cleaning spray, let it sit for a little bit, and then wash it out.
    May 2010
    327
    Thank you. Tried this early on thinking similar issues. Issue seems to simply be getting worse with time. Something is failing so I'd best be prepared.
    WW
    Quote Originally Posted by jwatte View Post
    May 2010
    327
    Quote Originally Posted by rdsi View Post
    Thank you for the link and for sharing. Sort of tempted to try and pull something similar off with one of their all in one touchscreens - thoughts on this? I have no need for the computer to do anything other than run PathPilot quite frankly.
    WW
    Dec 2015
    38
    Without wishing to hijack the thread to much I too would be interested in what rdsi thinks of the all in one touchscreen.I was interested in his new controller thread and this looks to be a very tidy way to go.Only needed to run machine .
  1. Replies: 7
    Last Post: 01-18-2017, 06:48 PM
  2. HDMI or Display Port on Tormach PathPilot Controller
    By nitewatchman in forum Tormach Personal CNC Mill
    Last Post: 11-15-2016, 09:25 AM
  3. Pathpilot conversational issues with append to file
    By remartinez in forum Tormach PathPilot™
    Last Post: 12-24-2015, 07:37 PM
  4. PathPilot probing Issues
    By MFchief in forum Tormach PathPilot™
    Last Post: 08-29-2015, 06:30 PM
  5. PATHPILOT COVERSATIONAL ISSUES
    By keen in forum Tormach PathPilot™
    Last Post: 08-17-2015, 10:12 PM
