587,236 active members*
3,833 visitors online*
Results 1 to 15 of 15
    Apr 2014
    185
    Lost power to the coolant pump
    G'day guys,
    Had an odd thing happen the other day. I suddenly lost power to the coolant pump.
    I've got an 1100 - Series 3
    I opened the cabinet and checked (with a Multi-meter) and there's no power at the socket, that the pump (power lead) is plugged into.
    If I toggle the Coolant button on Path Pilot, I can hear a "click", but still no power. I did the obvious and checked all the fuses and they're all ok.
    Anyone had this problem before or have any ideas?
    Michael
    Nov 2012
    591
    Re: Lost power to the coolant pump
    The relay could have failed (even though it's clicking.) Or somewhere between cabinet input and relay could have failed. Or some wire could have come loose because of vibrations. Or some fuse can have blown (although you already checked this.)
    Hook up the meter and follow the signal into the relay and then out of the relay.
    Apr 2014
    185
    Quote Originally Posted by jwatte View Post
    Thanks for the info.... now all I have to do is find the relay.
    I'm not that good at reading wiring diagrams, but I'll give it a try.
    Michael
    Jun 2014
    1780
    check for loose leads in the circuit, blown fuse etc.
    When I ran coolant and didnt use it for awhile sometimes the pump will just seize up, I used to have to rotate the shaft and then it would be ok for awhile.
    mike sr
    Apr 2014
    185
    Quote Originally Posted by popspipes View Post
    As mentioned, I don't have any power to the socket, that feeds (power) to the pump.
    I'm actually working on it now, but I'm not very good at this sh!t.
    Thanks for the input.
    Michael
    Jun 2014
    1780
    Quote Originally Posted by RA-Bowtie View Post
    Michael
    Here the pump is 120V, I think yours is 220V, or they may use a stepdown transformer to power it if its 120V, may be a fuse in that circuit thats blown??
    mike sr
    Apr 2014
    185
    I've checked every fuse and they're all ok.
    I'm going to send Tormach an e-mail and see if they can help me out.
    Michael
    Nov 2012
    591
    You're saying the relay is clicking, so you can find it by turning it on and off and following the sounds :-)
    Apr 2014
    185
    G'day mate,
    I'll post a picture that shows the relay in question.
    As I mentioned, I can hear it "click", when I click on the Coolant icon in Path Pilot.
    Michael
    Apr 2014
    185
    Here's the socket, that (as I mentioned) has no power going to it and also the relay.
    Michael
    Mar 2007
    2083
    have you lost coolant power with the switch in manual ?
    are the outlets for the PC & monitor working ?
    if you have just lost coolant pump power in auto
    you will need to check the the coolant pump switch
    and the fuse on the PCB - not sure from your photo if its F2 or what I expect is F1 next to the relay
    ( I can not read the marking on the PCB)
    the middle wire 204 (common) on the coolant pump switch should go to the live / hot terminal on the coolant pump outlet
    the outer two wires on the switch should go to the relay terminals on the PCB
    download the manual
    UM10349_PCNC1100_Manual_0916A_WEB
    https://www.tormach.com/support/wpdm...ual-0916a-web/
    the readable copy of the wiring diagram is on the last page
    John
    PS
    going by the manual , your photos and this photo off the net
    Attachment 400730
    this is how the 110V supply is connected to the coolant pump
Name:	Tormach wiring.jpg
    if you connect wires 202 & 205 together and the pump runs in auto
    you will know the fault is on the PCB
    I am not 100% sure if J5-1 on the PCB goes to the on board fuse or the relay contact
    you will have to check with your meter to see
    if the fuse is connected to J5-1 and relay contact to J5-2 or vise versa
    wire 202 is the live to the PC outlet switch
    wire 203 is the switched live to the PC supply outlet
    PPS
    Attachment 400752
Name:	Tormach wiring diagram with additional labels.jpg
    Mar 2007
    2083
    the photo's are too low a resolution to read the part number on the relay but
    I expect the relay to be like this -
    Attachment 400800
    data sheet
    https://docs-emea.rs-online.com/webd...6b8142189a.pdf
    John
    Apr 2014
    185
    Quote Originally Posted by john-100 View Post
    data sheet
    John
    Hi John,
    Thanks for all the info, it really was a big help.
    That is, until I realised that I had a major "brain fart" and (wrongly) thought that the 204 wire was power
    coming in from the master switch.... Doh!
    A couple of days ago I had crawled under the enclosure and my back had dislodged the power socket, from
    the wall....Sh!t !!
    At least your help pointed in the right direction, thanks for that.
    Michael
    Mar 2007
    2083
    A great result having a working machine
    problem solved without generating additional faults
    Been there got the T shirt
    At the end of a long day you can get fixated on one part of the problem and not see the whole picture
    only after a break do you see whats wrong
    glad my reply helped
    John
    Nov 2012
    591
    my back had dislodged the power socket, from the wall
    I hate it when that happens! "is it plugged in" is something I have to ask myself with some frequency ...
    Glad you got it working!
  1. Lost coolant pump power.
    By jttoner in forum Tormach Personal CNC Mill
    Last Post: 02-22-2017, 08:21 PM
  2. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  3. Interact 1 mk2, No power to Heidenhain 151 B Mains After Coolant Pump Short
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2012, 03:29 PM
  4. 325 Coolant Pump
    By TurtleRacing in forum Tree
    Last Post: 04-02-2012, 07:51 PM
  5. power for coolant pump....
    By rppman in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2010, 09:36 AM
