588,490 active members*
4,182 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Weird grinding noise when referencing X axis
Results 1 to 12 of 12
    Aug 2013
    980
    I have a new noise that just started happening in my 1100.
    When I reference X axis the machine sounds normal but after it touches the X limit switch when it is referencing itself, it makes a grinding/groaning noise as it slowly moves to its reference position. It does seem to reference and I can use the machine. That is the only time it makes that kind of noise. Any ideas what might be going on?
    Nov 2012
    591
    Re: Weird grinding noise when referencing X axis
    How old is the machine? How many hours of runtime? Have you ever adjusted or re-tightened the gibs on the bed? When did you last pull the oiling handle?
    Aug 2013
    980
    Quote Originally Posted by jwatte View Post
    Hi Jwatte
    I bought the machine new in 2013.
    I’m not sure how many hours but typically it will get run approximately 5 hours a week.
    I’m a compulsive Oiler so that is not an issue.
    I’ve never checked/adjusted the gibs.
    Do you think the gibs at the x reference end have gone out of alignment and need adjusting? After messing with moving the black stop ramp, I did get the noise to stop but now it’s back.
    I only get this noise (kind of a stall/grinding) at the x reference. I looked at the stepper coupler and I did not see any slippage when this happened)
    Nathan
    Nov 2012
    591
    From what I've read here, checking the gibs would be a good thing to do. They might have worn, if you have 5 hours a week for 5 years on it!
    Aug 2013
    980
    Ok, I’ll start looking at YouTube videos on how to do it. It’s something I knew I would have to learn at some point.
    Oct 2010
    670
    Quote Originally Posted by CadRhino View Post
    You might start here:
    https://www.nyccnc.com/tormach-pcnc-maintenance/
    The Body Armor Dude - Andrew
    Aug 2013
    980
    Quote Originally Posted by smokediver576 View Post
    I’ll check it out
    Oct 2012
    42
    That could be the sound a stalled stepper makes. Try moving the block that activates the limit switch slightly closer to the center of the table.
    Aug 2013
    980
    Quote Originally Posted by cncoperator View Post
    Good idea. I checked that and there was no slippage.
    Weird thing, after running the machine for three hours straight the noise stopped. Maybe the ways were a little dry.
    Dec 2003
    673
    On my machine, the end limit bumper wasn't in the right place... maybe fighting the bumper?
    Jun 2014
    1774
    check the plug that plugs into the stepper driver from the stepper motor, mine would make wierd noises occasionally when the plug burned, luckily I caught it in time and it didnt destroy the mosfets in he driver.
    mike sr
    Aug 2013
    980
    Thanks for all the input.
    After lots of fiddling around it turns out that my ‘x’ axis limit switch was bad.
    I replaced it and it works great now. FYI I sanded the leads down and used De-Oxit in the leads to help maintain good contact.
  1. Grinding noise on X axis
    By Cairoid in forum Fadal
    Last Post: 05-02-2020, 12:07 PM
  2. Replies: 15
    Last Post: 02-26-2015, 02:07 AM
  3. Weird noise and motion too slow.
    By Elsa in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2014, 09:46 PM
  4. Weird noise from TL2
    By JohnJW in forum Haas Lathes
    Last Post: 09-03-2011, 06:55 AM
  5. Weird shuddering noise from X2 mill table
    By alex781 in forum Benchtop Machines
    Last Post: 09-21-2010, 02:22 AM
