587,611 active members*
4,007 visitors online*
Results 1 to 9 of 9
    Jun 2013
    3
    PRO 4824 Enclosure
    Hi All,
    May I ask if someone would share the most extreme measurements of their CNCRP PRO4824 machine with me? i.e. X axis proximity sensor to opposite prox sensor. Reason I ask- I need to build an enclosure for my machine (which I will order next week). I see the footprint on the website, but I am not certain it accounts for all components.
    Thanks!
    Jul 2017
    42
    Re: PRO 4824 Enclosure
    I have mine in a corner of our garage and have it about as tight to the back and left walls as possible.
    I wouldn't make anything smaller than:
    Height: 74.5" ( depends on what riser, motor, etc you have )
    Depth: 45.5" ( Including the prox sensors CNCRP sells )
    Width: 70" ( That won't allow the doors to open on the CNCRP control boxes )
    Hope this helps.
    Jun 2013
    3
    Helps alot!
    Much appreciated sir!
    May 2012
    4
    I set mine up in an enclosure with an internal 4' x 7' footprint. I forget the height but I gave myself 6" above the z-axis cable chain. Set up my own cable chain so it might not match your dimensions.
    Sent from my Pixel XL using Tapatalk
    Is this to help with sound or chips? Or both? How loud is the unit?
    Otto
    Jun 2015
    64
    Quote Originally Posted by oglenewinkel View Post
    Otto
    I would guess for sound - there are certainly less expensive ways to do chip/dust collection and maintain better access to the machine. Routers aren't quiet, but I think my dust collection is louder. I wear hearing protection as a matter of course in my shop, but it is separate from the house so less likely to bother other members of the household..
    Nov 2006
    1036
    I have a small 2x3 foot CNCRP Benchtop Pro that I enclosed. Here's a couple of photos. It provides about 9 decibels of sound attenuation and allows access to all 4 sides of my machine. Good luck with your build!!
    Jun 2015
    64
    Looks good, I like the way you did the vertical opening doors.
    May 2012
    4
    Otto
    The enclosure is for sound. The machine is in my garage in a townhouse community so I don't want to disturb the neighbors while I run the machine at night. As is it helps quite a bit with noise and I plan on insulating it. All the walls are bolted together with sealing strips so I can still access the back and sides if needed. Crawling inside the enclosure works too
    For dust collection, I've added a port for a vacuum hose and am in the process of making a dust shoe and boom arm for the hose.
  1. Ordering Pro 4824
    By LeeWay in forum Avid CNC
    Last Post: 06-14-2018, 09:15 PM
  2. New PRO 4824
    By PapaLima in forum Avid CNC
    Last Post: 08-23-2017, 05:07 PM
  3. Another Pro 4824 Build
    By GigaWatt in forum Avid CNC
    Last Post: 04-09-2016, 12:43 AM
  4. New 4824 build here
    By Carol in AZ in forum Avid CNC
    Last Post: 07-19-2015, 02:43 PM
  5. CRP 2448 PRO (not a 4824)
    By kjk2002 in forum Avid CNC
    Last Post: 03-18-2014, 08:57 AM
