588,687 active members*
6,188 visitors online*
Results 1 to 9 of 9
    Mar 2015
    15
    Trojan threat
    I installed uccnc on my windows 10 laptop. went to the shop and connected to the uc400eth. When I tried to run uccnc I got a windows defender popup
    saying I had a virus threat. the threat was trojan win32/zpevdo.a. If I let windows defender remove the threat it deletes my uccnc shortcut. If I look in
    the uccnc folder there is no .exe file to run from there. Anyone ever have this problem. What can I do.
    Thanks Jim
    35538
    Re: Trojan threat
    You can add an exclusion in Windows Defender.
    I run UCCNC on two Windows 10 PC's with Windows defender, and have not seen this, but I do have exclusions setup, as UCCNC will load faster iirc.
    Go to Windows Defender, then Virus and Threat Protection. Scroll down to Exclusions, then Add Exclusion, and select the UCCNC install folder.
    Mar 2015
    15
    Re: Trojan threat
    I can't even load the software. I have tried it on 2 windows 10 laptops and get the same results. This may have something to do with installing the latest
    windows 10 upgrade. I know for sure It was loaded on both laptops at one point. I will disable windows defender and see what happens. I never have gotten
    any threats in the past. Its not only uccnc but anything associated with uccnc, program data, start menu etc. Seems like anything I try with uccnc whether it the
    motion control or the software has not been cooperating.
    Thanks for the help.
    Jun 2004
    6618
    Re: Trojan threat
    You should not need defender unless you keep it connected online.
    Turn that rascal off.
    Lee
    Mar 2015
    15
    Re: Trojan threat
    Thats exactly what I just did. Loaded fine on both machines. I think it will be ok now. had to be the new win 10 upgrade.
    Apr 2014
    59
    Re: Trojan threat
    It is a false positive. While installing, disable Defender. When the setup is ready, exclude the UCCNC folder. Disabling Defender is a temporary solution, because when Windows starts it will be enabled again.
    Feb 2010
    114
    Re: Trojan threat
    Build 2047 does not have this possible trojan virus. So I guess the question is what major change between build 2047 and 2048?
    I uploaded the file to virustotal.com and it showed 3 types of trojan/malware/adware for the latest build 2048.
    If your cnc controller pc/laptop is not connected to your network/wifi etc. then I guess you have nothing to worry about.
    But if you move gcode via a usb thumb drive from your cad/cam computer to your laptop with ucncnc then you are possibly infecting your other computers if this turns out to be a true virus.
    I show some older past builds has similar issue, but then other builds after that did not have the issue.
    35538
    Re: Trojan threat
    It's not a virus. CNC Drive has posted some additional info on their user forum.
    It seems that AV software is just looking at different things in the .exe files since the latest Windows Defender update.
    35538
    Re: Trojan threat
    A new version of UCCNC (1.2049) was just released that contains a fix for the false positive virus issue.
  1. UCCNC Trojan Horse?
    By DDgitfiddle in forum UCCNC Control Software
    Last Post: 08-09-2017, 03:17 PM
  2. AntiVirDog Trojan
    By MrWild in forum Community Club House
    Last Post: 09-18-2010, 05:47 PM
  3. threat cutting problems
    By phx in forum Fanuc
    Last Post: 10-01-2008, 02:30 PM
