587,263 active members*
3,379 visitors online*
Results 1 to 2 of 2
    Sep 2018
    10
    turret index issue
    Doosan lynx 300M
    Fanuc i series
    Every time I try and index counter clockwise, it goes 2 tool locations instead of 1, then errors with a 2119 tool change timeout.
    Proximity sensor seems to be working.
    Tools are fairly balanced, run for 2 weeks before this issue turned up.
    If I go clockwise, it works normally.
    Running machine with M180's Infront of tool changes to keep it running but...
    Any ideas why counter clockwise is being weird?
    Dec 2005
    68
    Re: turret index issue
    i have a similar problem on my puma 200 and was a small relay , i switched for the one that control the light and solve the problem but not light , i replace all of them, no more problems, was not to expensive
  1. need help with puma gt3100l turret index issue
    By trademark in forum Daewoo/Doosan
    Last Post: 02-16-2018, 12:01 PM
  2. Turret index question
    By stude8 in forum Okuma
    Last Post: 02-21-2017, 06:52 AM
  3. Sb4gn Turret does not index
    By SHAILESHSHEOREY in forum Hardinge Lathes
    Last Post: 01-29-2017, 05:45 AM
  4. Turret index speed
    By DocHod in forum Servo Motors / Drives
    Last Post: 03-07-2008, 04:24 AM
