Originally Posted by
GME
If Nate maintains the .1 mm spec he advertises, I can live with it. I'll just buy some .001" shim washers and call it good. Even though I favor the epoxy bedding method (I know, you don't), I doubt I would bother with it to close a gap as small as .004" at its worst.
I agree that any welding process will cause some distortion - even it's as little as .1 mm. I talked about it in PLJack's build post, when the subject of a gap came up. I'm hoping that mine meets the advertised spec, or very close to it. If it doesn't, I'll work with Nate to get it sorted out.
On the stand, I don't see any functional difference in putting the stand together an 1/8" in in the air, or on the ground. I acknowledge that I may be missing something, but, so far, no one is filling in my knowledge gap. For me, the question is whether I can get the holes to line up where the stand mounts to the CNC frame. What I want to know in advance is whether there is some play where the legs and come together with the horizontals. I rarely see anything bolted together where there isn't some play. Whether there is, or the extent, will help me decide how I want go about it. I'm trying to avoid drilling out holes, if I can avoid it. That's the answer to your "Why not assemble it first like I did" question. I may end up doing it like you did (or are going to do), but I'm willing to spend a little extra time exploring an alternative. I'm retired and may or may not use the machine for profit. So, an extra hour or two spent looking at a different approach is no big deal to me.
Thank you for your input.
Gary
