Well written article to sell epoxy and epoxy grouting. Good for mounting a laser or sewing machine. Our millwrights would never use anything like that.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
Here is an indepth article on the proper use of commercial grade epoxy to set machines on prepared concrete surfaces. They stress minimum thicknesses of epoxy even for that.
https://assets.master-builders-solut...y_Grouting.pdf
My research finds Gary is correct but only if the proper procedure is followed and the grouting is more like an epoxy bonding to both surfaces. This would make the bond between the gantry and bearing mount permanent. That is what makes it work. Otherwise I am sure it would crack.
Read more here> https://rlrowan.com/newsletters/pres...chinery-bases/
The framing reference is a trade joke if you ever worked in the construction industry you would get it.
Sorry about the inside joke.
Just assembled it but don’t tighten the bolts all the way install the router with a engine hoist or something similar so you can keep most of the weight off the stand. Then just line up the holes bolt them down and tighten everything up, then you can take the router off the hoist. I’m not really sure why everyone has such a hard time with something simple. Of coarse there is play in the bolt holes there has to be some tolerance or you would never get all those bolts installed. If you’re worried about it just open the holes up a bit prior to mounting the router.
No worries, I worked with a guy that used to say “can’t see it from my house”. I’ve seen some pretty unbelievable things in my life with construction where you say to your self “how in the world did that pass inspection”. .
I’m sure if you looked closer at your house you would see so many gaps that you could stick a quarter in that you would need a loan to fill them all. That’s why the finish carpenters make a lot more money.
I know exactly what you mean. When I remodeled my kitchen a couple of years ago, I found that the walls were way out of plumb. I hadn't intended to tear out all of the sheetrock, but the out-of-plumb condition sealed the deal. When I put up new rock, I used drywall shims and had to cut a kerf and sister on a couple of the 2 x 4s to get the wall where they should be. Some of it has to do with the relatively poor framing materials used in the last several years, but when I checked form plumb from plate to plate, it was clear that the walls weren't framed plumb. Anyway, it was worth the effort. The new wall cabinets went up like a dream, without any additional shimming. Also, my glass subway tile backsplash went on without even a hint of lipping. Did I mention that I HATE everything about drywall????
I guess I shouldn't have been surprised, but I was. My house was built as a full custom job and way overbuilt throughout. I expected better.
Gary
