I’ve just wired up a spindle and 2.2kw air cooled spindle. I’ve programmed in a few perimeters into the inverter to set the 400hz frequency etc. With no load its current top rpm is 18,200, where as it rated for 24,000rpm?! What setting should I be looking at programming to set up this particular inverter correctly?
Obviously life would have been a lot easier if i’d bought a Huanyang with all the posting about the set up of those but it wouldn’t fit the enclosure
Heres a couple of the scans from the XSY-AT1 manual although this list below might be more useful.
P00 Max voltage
P01 Reference frequency
P02 Intermediate voltage
P03 Intermediate frequency
P04 Min voltage
P05 Min frequency
P06 Max operating
P07 Min operating
P08 password
P09 password
P10 working frequency
P11 start stop
Additional to this will be programming 2 poles, 6amp motor rating and rpm if I can find the program number!
Spec:
Inverter
XSY-AT1
Model: AT1-2200X
Ver: A03
Power:2.2KW
Rated Current:12A
Input:1PH AC 220V 50HZ/60HZ
Capacity:8.0KVA(2.2KW/3HP)
Output:3PH
Spindle
Power: 2.2kw air cooled
?Voltage: 220VAC
?Current: 6A
?Frequency: 400 Hz
?Speed: 24000 rpm
Attachment 403788
![Click image for larger version.
ID: 403790](https://en.industryarena.com/forum/attachment.php?attachmentid=403790&d=1539159212&thumb=1)
