587,322 active members*
3,104 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > check #33.3 : longer string available for the subprogram name
Results 1 to 3 of 3
    Jun 2015
    4156
    if #33.3=1, is possible to use CALL O+16chars; pls check attached
    for example CALL OOOOOHOOOHOOOHOOO / OWHATISTHIS / WHEREISTHEDRILL / OMFG etc
    Apr 2014
    18
    Re: check #33.3 : longer string available for the subprogram name
    Hi deadlykitten, there is also on P300M?
    Inviato dal mio SM-G950F utilizzando Tapatalk
    Jun 2015
    4156
    hello okuma85, i just checked on the mill, and #33.3 seems to be there for something else
    maybe you will find some patience & time, so to scroll through all those bits on the mill
    if you wish, i will search on my control
    also, inside lathe manuals, there is nothing at #33.3; pls check attached
    i found that setting by mistake, while i was looking for something else
    do you really need such long names ? i always believed that you are a 16+chars kind of person / kindly
  1. String serving machine
    By dmh13433 in forum Other Machine Topics
    Last Post: 12-01-2018, 12:25 AM
  2. Cam-post string concatenation?
    By yar_seliva in forum Post Processors
    Last Post: 10-31-2013, 01:32 AM
  3. 18T dowload to pc no eob just long string
    By karlbushnell in forum Fanuc
    Last Post: 01-28-2011, 02:55 PM
  4. Zap String
    By Aplus in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2009, 05:01 AM
  5. Check Subprogram Exists
    By guypb in forum Fanuc
    Last Post: 02-22-2008, 08:42 AM
