587,997 active members*
2,040 visitors online*
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Jul 2003
    1759
    Re: small mill project.
  2. #22
    Jul 2003
    1759
    Time will tell if it will work....
  3. #23
    May 2008
    1185
    CNC paint brush!
    youtube videos of the G0704 under the name arizonavideo99
  4. #24
    Jul 2003
    1759
  5. #25
    Mar 2014
    1132
    Quote Originally Posted by samco View Post
    brilliant idea.
    Sent from my MI 5s Plus using Tapatalk
  6. #26
    Jul 2003
    1759
    homing working
  7. #27
    Jul 2003
    1759
    found my perfect laptop for me... (for cad and testing linuxcnc...)
  8. #28
    Jul 2003
    1759
    Analog spindle control with feedback.
  9. #29
    Jul 2003
    1759
    putting it all together... a bit of sheet-metal/plastic...
  10. #30
    Jul 2003
    1759
    more tinkering
  11. #31
    Aug 2005
    301
    SAMCO ,
    I have sent you a PM .
    ErnieD
  12. #32
    Jul 2003
    1759
    nothing really new..
  13. #33
    Jul 2003
    1759
    Trying a different spindle drive...
  14. #34
    Mar 2013
    88
    Nice work. Good to have a big mill when making a little one
    Have you used it enough to determine if the Y axis chip shield works? I didn’t know if chips would jamb up against the table?
    I may steel your idea for my Acer
    Keith
  15. #35
    Jul 2003
    1759
    adaptive feed with spindle power...
  16. #36
    Jul 2003
    1759
    working on getting a spindle encoder mounted.. There isn't an easy way to mount an actual encoder - so I went with a gear and using gear tooth sensors..
    Machined a gear and mounted it to the spindle pully (the gear was something we had laying around...) 36 tooth + index
    This is where is is going to live...
    Testing the index hole... (pully flipped...)
    Making a bracket... (the gear tooth sensors will be potted when I am sure the quadrature signal looks good)
  17. #37
    Jul 2003
    1759
    More spindle encoder....
  18. #38
    Jul 2003
    1759
    View of the sensors..
  19. #39
    Jul 2003
    1759
    A really high production quality video..... Rigid tapping
  20. #40
    Jul 2003
    1759
    Side tracked..
Page 2 of 3 123
  1. small EDM project (DIY EDMers welcome!)
    By acannell in forum EDM Discussion General Topics
    Last Post: 01-08-2014, 02:41 PM
  2. My Manual small mill project
    By ZipSnipe in forum Vertical Mill, Lathe Project Log
    Last Post: 05-07-2013, 05:03 AM
  3. Need Help with Small Project
    By mgilbert754 in forum MetalWork Discussion
    Last Post: 08-17-2007, 05:37 PM
  4. Small Mill Part/Project/Thing Showcase
    By BrendaEM in forum Benchtop Machines
    Last Post: 08-01-2007, 06:25 PM
