Given the z-axis' plate width, what is the maximum travel along the width of the machine?
granite surface plate is 900mm x 600mm Z axis plate with is 200mm so the travel is 700mm
Given the thickness of the gantry, 2 times rail and bearing thicknesses, thickness of the two aluminium spacer plates on the z-axis, and the radius of the spindle housing, what is the maximum machineable depth?
i guess it will depend on the length of your endmill. Z axis travel is around 160mm
What is the clearance between the gantry and the surface plate?
around 180mm.
