587,349 active members*
3,695 visitors online*
Results 1 to 5 of 5
    Apr 2003
    99
    What is Volt-Amp?
    I have a transformer which it's labelled 24 VAC and 40 VOLT-AMP. How do I figure out the current rating mathematically?
    Thanks.
    Sep 2003
    18
    40VA/24Volts=1.6 amps or so,VA is just another term for power similiar to watts. Larger transformer are usually rated in KVA.
    Steven
    Apr 2003
    99
    Looks like power in watts is about 65% of VA.
    Am I correct?
    Dec 2003
    24223
    The reason the wattage in a transformer is not the direct product of the voltage x current as it is in a DC or AC resistive circuit is that a transformer is an inductive device, so the voltage wave form leads the current wave form so they do not exactly peak at the same time. So in order to calculate the actual wattage rating this amount of lead has to be known and is known as the power factor, and varies on the device and the operating conditions etc.
    An extreme example would be a perfect inductance where the phase shift was 90deg. Voltage would be applied and current would flow but wattage or power would be zero.
    In circuits with a poor power factor, a capacitor can be added to compensate for the phase shift because in a capacitor the voltage LAGS the current.
    Al
    Aug 2003
    114
    Stevenpats is right, its not 65%. Its 24V, 40 Watts. Maybe you confused the 24Vac with watts?
    John
  1. West Amp Servomotor help
    By johnd in forum Servo Motors / Drives
    Last Post: 12-11-2008, 10:20 PM
  2. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  3. Need a low cost 4 amp, 48 volt, stepper drive
    By Mini Miller in forum Stepper Motors / Drives
    Last Post: 12-15-2004, 08:29 PM
  4. servo and amp question
    By cncfoam in forum CNC Machine Related Electronics
    Last Post: 01-19-2004, 11:25 PM
  5. 200 Oz-In 6.5 Amp Bipolar Parallel
    By motomitch1 in forum CNC Machine Related Electronics
    Last Post: 05-06-2003, 08:07 PM
