Re: Huanyang Inverter How to set and wire spindle at speed
The Parameters are PD050 to PD053.
Set to 5 (program reach) as they call it.
Depends on if you use the relay or the open collector transistor output.
page 19
There is also a At zero Speed.
Setting up is dependent on what you intend doing with the signals and what kind of system you are using.
I have used the At Speed signal for e.g. to register a FIN(ish) signal that hold up the next move until the spindle is at the programmed speed in order that there is not a move into the part until the spindle is up to speed.
Al.
Albert E.
