588,212 active members*
4,230 visitors online*
Thread: Saturn 2x4
Page 1 of 2 12
Results 1 to 20 of 22
    Nov 2018
    16
    Saturn 2x4
    Just received my Saturn 2x4 and everything looks good, but wife says it has to stay on pallet til after Christmas. After reading all the posts, I wanted to check the machine before I unpacked it and my question is: Without the steppers attached, how much force should it take to move the gantry on the x and y axis? It seems to move without any binding, but I thought the linear motion bearing would make it move a lot easier. Am I getting some restriction or does it take a little force(guessing bout 5-10 lbs force) to move gantry?
    Joe
    Re: Saturn 2x4
    Joe, the gantry is 150 lbs. you should be able to push it with one hand in the center.
    Fine Line Automation
    www.finelineautomation.com
    Nov 2018
    16
    Re: Saturn 2x4
    Yes, I knew the gantry was pretty solid and I am able to push it with one hand, but it does take some force. I was just concerned that the steppers were not going to be able to handle it. I noticed the grease fittings; so do I need to lube the bearings now or are they done during assembly?
    Joe
    Re: Saturn 2x4
    Quote Originally Posted by Joesmo View Post
    Joe
    We don’t lubricate the bearings at the factory because it can make a mess in transit. Lube with a NGLI #2 grease. Also, if the machine was out in the cold it tends to be a little stiff.
    Try the grease and email us if it still feels stiff.
    Nov 2018
    16
    Re: Saturn 2x4
    Ok, thanks.
    Sep 2005
    1740
    Re: Saturn 2x4
    This is the official grease recommend by the mfg > https://www.ebay.com/itm/Gadus-S2-V1...72.m2749.l2649 some NLGI 2 greases are very tacky I found out. This is what I ordered and use.
    If you loosen the gear drive on both side and drop to disengage the rack, keeping track of the measurement or counting the turns the gantry will very easily move with one hand.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Nov 2018
    16
    Re: Saturn 2x4
    Thanks for the recommendation on the grease. I have not yet installed the gear drive.
    Nov 2014
    722
    Re: Saturn 2x4
    I'm using Royal Purple NLGI #2 - works perfect for this application.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Aug 2018
    621
    Re: Saturn 2x4
    How's the machine going? Any pictures yet?
    Nov 2018
    16
    Re: Saturn 2x4
    Got the the frame welded and the machine up on it with no problems. Attached the spindle yesterday and have been ordering parts to build the control box. I'm still a little worried about the gantry movement. I've read some of your earlier posts and saw where you had trouble with binding and replaced your gantry. Someone posted that they can push their gantry and it will continue to move. Mine only moves when being pushed even after being lubed. How can I tell if it needs to much force to move. The x axis moves with about the same amount of force.
    Joe
    Aug 2018
    621
    Re: Saturn 2x4
    I didn't know on my table until I had everything installed and started jogging the y axis but I immediately was concerned because I could feel it stick in certain places while moving it by hand. I actually notified Nate of the problem before I even took the router off the pallet. At that time no one had reported any issues so I just thought it was because the bearings needed to be greased.
    Turns out it immediately started binding once I started jogging the axis and wasn't reliable until I loosened up all the gantry bolts and as soon as I tighten them back up it would bind up again and I had to keep them loose until I got my replacement beam. It's great now and I'm very happy with how it cuts so far.
    Post some pictures of the table so I can see if yours is the same as mine. Also what did Nate have to say about it? Has he responded to you yet about your concerns?
    Dan
    Nov 2018
    16
    Re: Saturn 2x4
    Dan
    It does not seem like it is sticking, but I expected the gantry to somewhat float on the bearings. I havent installed the gears yet because I am waiting on the motors I ordered from Nate. Nate responded to an earlier post about lubricating the bearings and to let him know if I still have issues. I'm not quite sure if I have an issue because I'm not sure how freely this heavy gantry should move. I have loosened the bolts but it did not make that much of a difference. My question is, how do I tell or is there a test to how freely the gantry should move on the Y-axis? Nate says I should be able to push it with one hand and I can, but I thought it should be a little easier. Maybe it is me not being familiar with cnc routers that is causing the issues.
    I'll get a pic up tomorrow when my wifes car isn't in the way.
    Joe
    Re: Saturn 2x4
    Dan
    Joe
    Remember that gantry is 150 lbs. It’s definitely not going to be as easy to move as just a plain carriage because of the weight. You shouldn’t feel like you have to shove it hard to move it.
    If you are concerned, we would suggest loosening the bolts on the machine. See how it moves with the bolts loose, then tighten the bolts again and realign. If there is a noticeable difference, let us know and we’ll do additional troubleshooting.
    Nov 2018
    16
    Re: Saturn 2x4
    Did a little of the bolt loosening today with just a very small improvement. Will try a more comprehensive realignment tomorrow and see if anything changes. Can you post a video showing the gantry movement without motor power?
    Aug 2018
    621
    Re: Saturn 2x4
    Cool looking forward to seeing your table since I haven't seen a new 2x4 table yet. I'm curious to see if it's the same as mine.
    Nov 2018
    16
    Re: Saturn 2x4
    Photo of completed stand. Does this movement appear to be like everyone elses? https://youtu.be/7kF2JB_ee_8
    Nov 2014
    722
    Re: Saturn 2x4
    It's been a while since I disengaged the stepper motors but yes, that's how ours moves. At least that's how I recall it moving.
    David
    David
    Romans 3:23
    Re: Saturn 2x4
    That looks about right.
    Jan 2007
    251
    Re: Saturn 2x4
    Same here. Looks good.
    Jack.
    Aug 2018
    621
    Re: Saturn 2x4
    I wish mine moved that smoothly when I first got it. You are one of the lucky ones my friend, I obviously got a got a lemon lol. The stand turned out good looking forward to seeing it finished up.
    Dan
Page 1 of 2 12
  1. Log Carving with the Saturn 2
    By wmgeorge in forum FineLine Automation
    Last Post: 09-26-2018, 02:17 AM
  2. New Saturn 2x4
    By Erik F in forum FineLine Automation
    Last Post: 05-01-2018, 06:24 PM
  3. Saturn 4x2
    By coherent in forum FineLine Automation
    Last Post: 03-15-2018, 11:51 PM
  4. Saturn 2 - 4x4
    By liqdfire in forum FineLine Automation
    Last Post: 12-05-2017, 01:28 AM
  5. Saturn 4x4
    By GoFigure in forum FineLine Automation
    Last Post: 04-03-2017, 04:36 AM
