587,998 active members*
1,692 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Control 6 axis and 5 axis cnc machines from a single computer
Results 1 to 7 of 7
    Dec 2018
    3
    Wondering if anyone has any recommendations on how to control a 6 axis cnc machine and a 5 axis cnc machine from a single computer.
    I am developing a cnc system that is comprised of a 6 axis machine and a 5 axis machine. It is not necessary for all 11 axes of the system to be synchronized, but the axes of each individual cnc machine (i.e. the 6 axis and 5 axis machines) do need to be synchronized. One machine will finish an operation before the other machine will be commanded to perform the next operation. The two machines do not need to operate simultaneously.
    Up to this point I have been using Mach 3 for each individual machine. My current thought is to run two instances of Mach 3 on a computer and develop a script that will sequentially send the g-code to each instance of Mach 3. If I can't run two instances of Mach 3 on a current computer was thinking of running a single instance of Mach 3 on two computers and using a third computer to send the g-code to each instance of Mach 3.
    An 11 axis cnc controller would certainly work but I am on a tight budget for this project and it seems a little overkill since not all 11 axes need to be synchronized.
    35538
    Re: Control 6 axis and 5 axis cnc machines from a single computer
    I believe that you can run two instance of UCCNC with two controllers on one PC. Contact CNCDrive to verify.
    You can't with Mach3.
    Mar 2015
    418
    If you can sent the gcodes to mach3, than any 5/6 axis controller having an "open" interface can do the job.
    Dec 2003
    24220
    Post an inquiry here to see if Dynomotion can do it.
    It is an external controller so it may be possible.
    Al.
    Albert E.
    Dec 2010
    45
    We can do it easily.
    2x myCNC controllers, 2x instances of myCNC control software for each controller.
    myCNC software has Server API through TCP Sockets.
    You can run your script to control both instances of myCNC software, load and run a job, get current states, emulate pendants etc.
    Dec 2018
    3
    Since this is a hobby project my budget per stepper motor controller is just $200.
    Found a 5/6 axis Mega2560 fork of grbl that looks promising (https://github.com/fra589/grbl-Mega-5X). Seems that I could develop a gcode sender script that sends commands to the two machines using USB serial.
    Dec 2018
    3
    Thanks ger21.
    I did contact CNCDrive. Yes, you can run multiple instances of UCCNC on a single computer. You can also send gcode to UCCNC but you have to write a plugin to do so.
  1. Single axis stepper control setup
    By harryn in forum Gecko Drives
    Last Post: 05-01-2018, 04:40 AM
  2. Replies: 7
    Last Post: 07-14-2014, 11:11 AM
  3. analog control for a single axis stepper
    By cstmwrks in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2014, 03:04 AM
  4. Single axis control
    By Dick L. in forum Controller & Computer Solutions
    Last Post: 05-10-2011, 12:17 AM
  5. single axis control?
    By jayty97 in forum Stepper Motors / Drives
    Last Post: 04-08-2009, 01:05 PM
