Quote Originally Posted by Hezz View Post
Nice work Petruscad, it's coming together slowly but surely. Do you have a surface plate large enough to get readings on the other side once you turn it over?
And will you be using the same scraping technique on the EG surface. Or do you have steel mounting rails on the other side?
where did you source your precision flat straight edge?
