need to modify post so % character is at very top of program.
right now the problem is turret and tool description are posting above % character.
help please
Eric
help please
Eric
Hi!
Do you have the CGD files for the postprocessor?
Im not an expert here, but it should be easy.
-Robert
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
was attached
Ok, thanks, is this a file\postprocessor you have payd much money for? then you should not upload it, i was asking only about that you have the file, so you can change it
I don`t have time right now, but i will take a look at it in a few hours
Thanks, I am not an edgecam user just trying to help fellow programmer out with this.
He does no have much experience with post edits.
So any help is greatly appreciated.
Should I remove the previously attached file?
So you only need a % symbol at the start, and NOT on the end? or do you need in both places?
both
If the guy pay for example $2000 so... YES!
If he get it for free, i think you can leave it here
Do you wan`t it back with the adjustment? or do yoiu want to try to fix it if i told you what you should do?
Send me an PM with your email adress, and i send it back with the % symbol in start and end
whatever you think would be least effort for you - remember is old version
Im done with it. So just send me you email adress
sent pm
PP sendt
ok now problem we have is % character in front of each turret and tool description in the header, (is multi tool program). We need only one occurrence at very top and one at very end of program.
Ok, give me some minutes
Hmm... I can`t place it before the tool information, only after the tool list..
But give me some minutes/days i will figure it out
New PP sent!
now programs are missing % character at top
Hmmm.. Wierd, that work for me..
-Check it-
Here is the .nc code i get out.
Please check that you are using the latest PP
(* Turret Position : 1 Tool Description : 25.0 mm Multi-Flute End Mill)
(* Turret Position : 2 Tool Description : 8.0 mm Multi-Flute End Mill-LS)
( Innovative Engineered Solutions Inc.)
(* Machine Tool : Chevalier Mill)
(* Part Name : Parasolfot Chavalier test)
(* Sequence : Operation 1)
(* Programmed By : )
(* Date : 01/30/19)
(* Time : 22:31:49)
(* Total Machining Time : 6.407 Minutes)
O0001 (Parasolfot Chavalier test)
G17 G40 G80 G90 G94
G00 Z3.0
X0.0 Y0.0
T01 M06 (25.0 MM DIA MULTI-FLUTE END MILL)
M3 S9999
G00 G55 X0.0 Y0.0
G43 Z3.0 H01
G00 X0.0 Y0.0
Z1.9685
M8
X0.1969 Y-1.8102
Z0.1969
Z0.1181
G01 Z-1.2598 F7.87
Y-1.7315
G17 G03 X0.0 Y-1.5347 R0.1969
G02 I0.0 J1.5347
G03 X-0.1968 Y-1.7315 R0.1969
G01 Y-1.8102
G00 Z0.1969
Z1.9685
X0.0 Y0.0
Z3.0
X0.0 Y0.0
M9
M05
T02 M06 (8.0 MM DIA MULTI-FLUTE END MILL - LS)
M3 S9999
G00 G55 X0.0 Y0.0
G43 Z3.0 H02
G00 X0.0 Y0.0
Z1.9685
M8
X0.1969 Y-1.4756
Z0.1969
Z0.1181
G01 Z-1.2598 F7.87
Y-1.3969
G03 X0.0 Y-1.2 R0.1969
G02 I0.0 J1.2
G03 X-0.1969 Y-1.3969 R0.1969
G01 Y-1.4756
G00 Z0.1969
Z1.9685
X0.0 Y0.0
Z3.0
X0.0 Y0.0
M9
M5
G00 Z3.0
X0.0 Y0.0
M30
