588,169 active members*
4,738 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huayang VFD GT series Auto tuning
Results 1 to 15 of 15
    Jan 2008
    19
    Getting a new spindle dialed in here.
    When I run the autotuning function; 5 minutes in, the VFD errors out with a OV3.
    The manual says that is for: " the input voltage changes abnormally", OR "Inertia of the load is big"
    solutions being:
    "install input reactor"
    "add proper consuming components"
    I'm not sure exactly what the problem is, or the solutions for that matter...
    anyone have any ideas.
    The spindle seem to run fine, although I have not ran the RPM's up as high as the auto-tuning seems to.
    Its a 4.2kw spindle, and the VFD is 7.5kw
    maybe it too oversized?
    thanks
    landy
    15362
    Re: Huayang VFD GT series Auto tuning
    Quote Originally Posted by landy View Post
    solutions being:
    thanks
    landy
    I have found that you can only run these in V/F mode when the drive is to large for the spindle, the Drive can't program it's self, this seems to be a problem with the GT series
    You also can't do an auto tune unless you have all the needed Parameters set for your Spindle
    Mactec54
    Jan 2008
    19
    Do you think it would be better to get the 5.5Kw version? I think that is the closest rated one to my spindle.
    I have all the required parameter set, at least that I know of...
    thanks for your input!
    landy
    15362
    landy
    If you are using 3Ph power then you can have a VFD Drive that is close or the same size as the spindle Kw, if you are using single phase the you want close to double the size of the spindle Kw
    Mactec54
    Mar 2010
    621
    What motor are you running?
    I also have the GT version... The Tech support from HuanYang said I only needed to set 4 parameters and that was it and shared this video
    https://www.youtube.com/watch?v=eeiI...index=11&t=48s
    after which the autotune would take care of the rest, it did not.
    Anyway, these are what I set for my 3.5KW motor before running the autotune:
    P2.01=3.5
    P2.02=300
    P2.03=18000
    P2.04=220
    P2.05=15
    P0.03=300
    P0.04=300
    P0.06=300
    Hopefully it's helpful.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    15362
    Quote Originally Posted by adam_m View Post
    P2.01=3.5
    P2.02=300
    P2.03=18000
    P2.04=220
    P2.05=15
    P0.03=300
    P0.04=300
    P0.06=300
    Adam,
    If these are the only Parameters you set then you are running in V/F mode, which won't be a problem for the OP as well once he set his main Parameters
    If your VFD Drive is matching then you won't have a problem as well, but you do need to set more Parameters than that or you will be just running in V/F mode, which does not have any problem doing this in auto tune, it is when you use it in Vector mode that the VFD Drive is not working correct
    Mactec54
    15362
    solutions being:
    thanks
    landy
    The main thing is that you have all the main parameters set for your spindle spec's
    What are your Spindle spec's ??? I most likely have all the parameters you need to have set
    Mactec54
    Jan 2008
    19
    Attachment 411344
    I have the parameters set to match what is on the spindle.
    P2.01=4.2
    P2.02=400
    P2.03=24000
    P2.04=220
    P2.05=11.2
    P0.03=400
    P0.04=400
    i'm not using the keypad, so I don't think I set P0.06.
    I am also using 1 phase power.
    thanks again
    15362
    Attachment 411344
    P2.01=4.2
    P2.02=400
    P2.03=24000
    P2.04=220
    P2.05=11.2
    P0.03=400
    P0.04=400
    thanks again
    Ok this is what you need to set to get you going, Check that the Ground Terminal has continuity Pin 4 to Spindle Body if not this will have to be corrected
    These are what you need set
    Mactec54
    400Hz 220v 4.2 Water Cooled Spindle Settings
    P0.00=0 ( 0 for V/ F Control 1 For Vector Control )
    P0.01=0 ( 0 For KeyPad 1 For Remote Terminal Use )
    P0.02=3
    P0.03=400
    P0.04=400
    P0.05=120 ( you may be able to go lower depending on Spindle Temperature 100 Minimum )
    P0.06=400
    P0.11=10 ( adjustable Acceleration )
    P0.12=10 ( adjustable Deceleration )
    P0.14= 6 ( 6 to 8 )
    P0.17= ( 1 to Restore Factory Defaults ) ( 2 clears all Faults )
    P1.01=10
    P2.01=4.2 ( Motor Settings )
    P2.02=400
    P2.03=24000
    P2.04=220
    P2.05=11.2
    P7.14= ?? ( VFD Rated KW )
    P7.15= ?? ( VFD Rated output Amps )
    Once these Parameters are set, you can then do a Autotune, you set Parameter P016=1 and Press Run, ( The Spindle Must Be Clear To Run )
    For main input Power wiring connect R Hot T Hot and Ground to the Ground Terminal, this is your connection for NA 240v single Phase
    Mactec54
    Mar 2010
    621
    Mactec54,
    I'm unfamiliar with the "Speed Control Mode" between V/F and Vector Control... what are the advantages of using Vector Control?
    It also looks like its P0.00 = (1 or 2) not sure which I would choose... and if that is the only setting needing to be change to set it up.
    Adam,
    15362
    Mactec54,
    Adam,
    You are best staying with 0 as V/F as you would not see any difference, If you did want to try, it won't hurt anything, you would use ( 1 ) and then Auto Tune, if it does not run well after, then go back to ( 0 ) and Auto Tune again
    You would not see much difference with your spindle as the Torque is linear, there would be very little change if any from 12,000RPM to 18,000RPM
    It seems you only missed ( 1 ) main Parameter Minimum Speed P0.05 needs to be set at your spindle minimum speed spec's if it is Air cooled by the built in fan then the minimum speed would be around 12,000 RPM
    300Hz 220v Spindle Settings
    P0.02=3
    P0.03=300
    P0.04=300
    P0.05=120 ( Minimum Speed Yours may be higher than this )
    P0.06=300
    P2.01=3.5
    P2.02=300
    P2.03=18000
    P2.04=220
    P2.05=15
    Mactec54
    Jan 2008
    19
    Mactec54
    P0.02=3
    P0.03=400
    P0.04=400
    P0.06=400
    P0.14= 6 ( 6 to 8 )
    P1.01=10
    P2.02=400
    P2.03=24000
    P2.04=220
    P2.05=11.2
    Had a chance to check and change parameters to what is listed above.
    Then I ran the auto-tune, still errored out with OV3, but might have ran longer before doing so. I didn't time either run, so I cant say for sure.
    I have noticed that on occasion the spindle makes a high pitched squealing noise randomly, then it goes away. Not sure if its related or not?
    thanks for all you help!
    landy
    15362
    landy
    What mode did you try it in just do a regular P0.00=0 if this does not work and you have all the Parameters set correct
    It seems for that fault you have an input power problem, what is your supply what amperage do you have available You most likely will need a line filter and may be a reactor as well
    Mactec54
    Jan 2008
    19
    Yes, it was in P0.00 = 0
    its 220v single phase, from a 30 amp breaker in a sub panel.
    if I do need a line filter or reactor, do you have any recommendations?
    thanks!!!
    landy
    15362
    thanks!!!
    landy
    Spindle to VFD Drive cable is this 4 core and shielded
    30 amp is not enough for your VFD and spindle using single phase, your VFD is really to big for your spindle a 5.5Kw would be a better size, as the 7.5Kw is bordering max for single phase supply
    If you can change the VFD to a 5.5KW and you would need at least a 45A supply, I would start with a Filter which has to be rated for the max input amps of your VFD Drive when using single phase power, not the rating you see for 3ph power
    Any Breaker and its circuit's has to be sized correct for Code requirements, the input amps on single phase can be as much as double the output amps, when using single phase power, your Mains Breaker should be sized 125% more than the max input amps for the VFD Drive on single phase and wiring to match, the snip is what the output amps can be for a motor on single phase power
    Mactec54
  1. 2.2kw spindle and Huayang VFD
    By tkms002 in forum Spindles / VFD
    Last Post: 02-08-2019, 07:15 PM
  2. Huayang VFD Hidden Commands
    By squirrel_41 in forum Spindles / VFD
    Last Post: 09-09-2017, 06:19 AM
  3. Question about auto tuning a DM556 drive
    By millhead in forum Leadshine
    Last Post: 04-27-2017, 05:28 PM
  4. Auto-Series
    By happytriger2000 in forum Uncategorised CAM Discussion
    Last Post: 02-08-2008, 04:48 PM
