587,143 active members*
3,555 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > How to do spiral lead in for 2D contour multiple depth cut.
Results 1 to 9 of 9
    Aug 2018
    25
    Question How to do spiral lead in for 2D contour multiple depth cut.
    Hi!
    I'm new to this and working on my first hobby project (a rubber band gun). I'm trying to do a 2D Cutout with multiple depth passes from some plywood. I believe I've read some where that I should not do straight plunges or lead-ins directly into the wood, but instead do spiral cut downs into it. The 3D Adaptive clearing in fusion 360 does this automatically so there you don't have to worry. I can't use that method however as that wants to clear ALL of the plywood away and I just want to cut them out and leave small tabs.
    So I found 2D Contour, but with this is just plunging pretty much straight down (very slighly sideways). I'm using a flat 6mm carbide tool (this one), and just looking at it I would guess it's not supposed to be plunged directly down.
    How should I solve this, or is this not an issue, are there better tool paths I can use?
    Thank you for the help!.
    Attached Thumbnails Attached Thumbnails leadinandout.jpg   leadinleadoutbigger.jpg   WhatIWantToAchieve.jpg
    Jun 2008
    1838
    Re: How to do spiral lead in for 2D contour multiple depth cut.
    As far as I can tell, ( might be there but I haven`t found one yet) Fusion doesn`t have a proper Contour Ramping cut, the nearest I have as a "workaround" is a sort of part ramp where the tool will ramp down along part of the cut and then continue at the set depth instead of ramping all the way down as it goes around, at least in the sample program I have done.
    I have no doubt there will be a much better method of doing the full contour ramping where the tool is constantly moving in the Z as well as the X and Y
    Anyway, it might be of some use to you so here is an image of what I have done and the Fusion f3d file is attached in the Zip file, have a play around with the settings under the "Link" tab and see what you can get out of it
    Regards
    Rob
    P.S. Here is an image from a different CAD-CAM software that does do a full angled contour ramp, is that more like what you need ? I know none of thie above does a Spiral but it`s all I can come up with for now
    Attached Thumbnails Attached Thumbnails 2D Ramping.JPG   Full 2D Contour Ramping.JPG
    Attached Files Attached Files
    Aug 2018
    25
    Thank you for the information, I also stumbled across how to do it in Fusion 360.
    There is a Ramp option in Fusion 360. Se picture.
    Jun 2008
    1838
    Yes, that is what I used in my example, it is only a lead in ramp not a full ramping contour but if it is enough to get you going as a "workaround" then good enough
    Regards
    Rob
    Aug 2018
    25
    Quote Originally Posted by The Engine Guy View Post
    Ah, ok I misunderstood.
    By setting the lead in ramp step very low it pretty much did a ramp the entire way around. I think this will be enough for me for now. Or is it something else you mean that this does not do? I'm very new to this so I might not be understanding what you mean.
    Thank you
    35538
    For wood, I'd just ramp at 30°, or an angle that gives you a 1"-2" ramp.
    Jun 2008
    1838
    Quote Originally Posted by vosser View Post
    Thank you
    What I am meaning is a full proper Contour Ramping as in the image I posted earlier, the ramping is not a Lead-in but a full ramp that is continually moving down in the Z as the tool moves around the contour, it only stays at the same Z level when the cut reaches the bottom of the cut as it does one complete finishing pass at the full depth set. As far as I can tell Fusion 360 doesn`t have this simple strategy, shame as it is a very, very useful and quite quick cutting strategy
    It may well be somewhere in Fusion and I just haven`t found it yet, if it isn`t then I might put it up for the developement team to look at
    Image posted again JFYI
    Regards
    Rob
    Nov 2014
    724
    It's there. I use it all the time. The attached screenshot is from one of the Longworth chucks I cut regularly, this one is 16" in diameter. We've now cut over 90 of these and I see X, Y, and Z all changing as this is ramping down. If you set it like Gerry suggested for wood, 30° angle, it ramps down quickly. But the default seems to be 2° and I just leave it there on most jobs. Believe me, it definitely is a continual ramping profile.
Name:	2D Contour - Ramp.jpg
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Jun 2008
    1838
    David, hold my hand up you are correct, in my example I was a bit rushed and hadn`t noticed that "Multiple Depths" were still enabled under the "Passes" tab, disabled that and it works as I had expected it should
    Thanks for your input, got me to take a second look at VOSSERs original request
    Regards
    Rob
  1. V28 spiral lead in
    By Ben S in forum BobCad-Cam
    Last Post: 11-18-2015, 02:38 PM
  2. Replies: 8
    Last Post: 09-23-2015, 03:40 PM
  3. Contour depth in X4
    By adamchapman in forum Mastercam
    Last Post: 11-03-2012, 09:42 PM
  4. contour depth control
    By George777 in forum Mastercam
    Last Post: 02-26-2010, 02:21 AM
  5. x4 Contour and Depth
    By vdauer in forum Mastercam
    Last Post: 01-13-2010, 05:32 PM
