Originally Posted by
CNCMAN172
Yeah, the pulsated DC is causing the meter to get goofy. OK, let check something else. Set your meter back to ohms with everything turned off and unplugged from the wall. Now measure from the Motor common - negative lead and see if it is connected to the motor case. The Plus side should be going to the brushes inside the motor and the negative side should be going to the windings inside the motor. We are just checking to see if the winding a tied to the case. My guess is you will find them at infinite again.
