588,529 active members*
6,417 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Machine can't cut straight angled lines.
    Mar 2016
    4
    My machine is making jagged lines when cutting 45 degree angle paths.
    Anyone know why this might be? I've searched for loose screws and wobbly connects - but everything seems tight.
    Is there a quick fix for this glitch?
    Machine: CNCRouterParts Pro 48x96
    Cheers,
    S
    Sep 2005
    1740
    Re: Machine can't cut straight angled lines.
    Will it cut a straight line, will it cut a box accurately or do a circle the size its drawn at? If not it could be your Steps are off. Check and see or test.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Mar 2016
    4
    Found the problem!
    After tearing it apart - tte X axis belt was.... ruptured.
    Not sure how that happened.
    New parts ordered.
    Cheers!
    Mar 2016
    4
    Yup. New belt. Work perfectly now.
  1. Lasercad not engraving straight lines
    By ozeguru in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2019, 02:14 PM
  2. Replies: 7
    Last Post: 06-07-2012, 03:41 PM
  3. Straight Lines on Curved Surface.
    By Navatek in forum CNC Tooling
    Last Post: 08-15-2011, 11:45 PM
  4. problem with lines not cutting straight after engraving
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2009, 04:27 AM
  5. EMC G1 not producing straight lines
    By klick0 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-03-2006, 07:08 AM
