587,240 active members*
3,034 visitors online*
Results 1 to 6 of 6
    49
    Fanuc 21t mem.card slot
    Does anyone know if there is such a thing as a PCMCIA slot adaptor that I can just plug my flash drive into the other end?
    May 2003
    75
    Nope. Need an actual card.
    Paul Sevin - Ovation Engineering, Inc.
    http://www.ovationengineering.com
    Sep 2005
    767
    Those kinds of adapters are available, but as far as I know you can't load the necessary device drivers into the Fanuc control to make it work. I suggest that you just buy the SRAM card and get it over with.
    304
    Fanuc sells one that will use a compact flash card. They were here 2 weeks ago and showed it to us.
    Mar 2006
    167
    Quote Originally Posted by cogsman1 View Post
    You can use any compact flash adaptor (no need to buy from fanuc), but you are better off going for a better quality one. The cheap $5 ones on Ebay will sometimes give problems. I would be interested to know if anyone has used a microdrive/CFA combination. I don't know if it actually works, athough I believe it should work provided the microdrive is CFII compatible.
    regards, Oz
    Jan 2006
    59
    I bought my PCMCIA/flash card adaptor at Best Buy, and it works great.
    RRL
