Re: Will swap axis work properly with an axis that has a slave?
A lot of times when I do strange stuff that Fusion won't do directly, I post separate operations that generate the tool path that I want, then manually merge the G code. Sometimes this requires manually editing or writing the G code. Fusion will handle 5 axis operations, but may require modifying a post processor to get what you want. How's your Javascript programming skills?
Depends on what controller you are using to run your machine. You should be able to slave the B axis to the X (or any other axis) if your controller will handle it.
Sounds like you really need a full on horizontal machining center
Jim Dawson
Sandy, Oregon, USA
