588,098 active members*
5,067 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
Page 2 of 5 1234
Results 21 to 40 of 91
  1. #21
    Jan 2017
    31
    Re: Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
    No problem at all we are here to help
    Both look ok, except for one thing that stands out is the 5A rating for the spindle, I think that is incorrect that would be for a 380v spindle 220v spindle normally is 8A to 9A or close to it
    The VFD is a normal HY VFD and will work well
    Looking at the thumbnail picture, next to the main thumbnail picture, it shows 8A.
    So, everything else is good?
  2. #22
    Jan 2017
    31
    This is the picture I was referring to.
  3. #23
    15362
    Quote Originally Posted by cduncan64 View Post
    It's amazing how they screw up there advertising so much, but good to see you found the correct spec's
    Mactec54
  4. #24
    Jan 2017
    31
    I can understand how it happens. Cut and paste this cut and paste that. Just can't believe in why it happens.
    Ok, so unless you have any suggestions, I'm ordering that VFD and Spindle.
    Charles
  5. #25
    15362
    Charles
    You are good to go, Amazon is good to by from, have great deliveries, I can never say what you are getting is not faulty or is going to fail, everything is a gamble, at least with Amazon it can be an easy return if there is a problem
    Mactec54
  6. #26
    Jan 2017
    31
    While I am waiting for my VFD and spindle to arrive. I need to run a cable and install an outlet for the 220.
    That won't be so bad since the breaker box is nearby.
    The power cord that goes to the spindle I have now is rated at 10 amps. Thats 20% higher than the specified current for the new spindle (8 amps.) It is 16 Ga., 4 wires, 300VAC. Do you think that is ok?
    Thanks again.
    Charles
  7. #27
    Jan 2017
    31
    Please correct me if I am wrong. Is there an issue with running the VFD from a 220v outlet and everything else that is 110v (PC, Controller) going to a different outlet that my or may not share one of the 220v 'sides'?
    Should I run 220v to a box or enclosure and break out the 110v and 220v from there?
    Charles
  8. #28
    15362
    Charles
    Always better to use one supply you need an extra wire but worth it so to do the 240v/120v supply you will have ( 2 ) hot wires a Neutral white and Ground wire so 4 wires
    Mactec54
  9. #29
    15362
    Thanks again.
    Charles
    It has to be a shielded cable and Quality 16gauge is fine, only if it is shielded and with a high flex rating, the code requirement is 125%
    This is the cable that I recommend for the VFD to the Spindle CF6-15-04 there are other manufactures with similar cable https://www.igus.com/search?q=CF6-15-04
    Mactec54
  10. #30
    Jan 2017
    31
    I'm a McMaster type of guy. This specs the same.
    https://www.mcmaster.com/8082k45
    Charles
  11. #31
    15362
    Charles
    It looks like it is made by the same company, they have lots of reseller's the Shield looks a little open in the weave but may be just the photo
    Yes McMaster are easy to deal with
    Mactec54
  12. #32
    Jan 2017
    31
    Ok, both the VFD and spindle arrived today. YAY!
    When you get the time, can you please send me the VFD parms that I need to set to keep from damaging this equipment?
    Thanks again for all the help/advice.
    Charles
  13. #33
    15362
    Charles
    This should be all you need
    Huanyang Mactec54
    2.2Kw 220v 400Hz Water Cooled
    PD000=0 ( 0 For Parameter unlock ) ( 1 For Locked )
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=190
    PD007=20
    PD008=220 (Motor Rated Voltage )
    PD009=102
    PD010=15
    PD011=120 ( 100 Minimum Setting )
    PD13= 08 (is for Factory reset, Only use this to set VFD to Factory Default Settings )
    PD014=8 ( Acceleration Adjust to suit)
    PD015=8 ( Deceleration Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=120 ( Stall Prevention )
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum RPM Setting )
    PD174= ??? ( To Be Set to the VFD Drives Max Rated Output Current / Amps )
    Mactec54
  14. #34
    Jan 2017
    31
    Huanyang Mactec54
    PD003=400
    PD004=400
    PD005=400
    PD006=190
    PD007=20
    PD009=102
    PD010=15
    PD72=400
  15. #35
    Jan 2017
    31
    How does this sound?
    Even though my CNC is 15 ft away from the breaker panel, I would like a main shut off for everything (except PC).
    That means the
    VFD
    Smoothstepper wall-wart power supply
    and 48v 12.5 A power supply would all be fed from the same 220v box (sub panel? I don't know what its called).
    The subpanel would be fed with a cable that can handle 30 amps (10/3) or 40 amps (8/3).
    I don't have to enclose all the electronics in a $100+ enclosure/box do I?
    If I don't need a box for everything, then can I use something like a Square D 30-Amp Fusible Metallic Disconnect?
    https://www.schneider-electric.us/en...-30a-2p-nema1/
    Then, from the box breakout a 4 Gang 110v outlet and 1 220v outlet. Using conduit between the outlet boxes to keep it nice looking.
    If all this above is nonsense, do you have a link to a diagram or picture of an install I can follow?
    Charles
  16. #36
    15362
    That means the
    VFD
    Charles
    You really should have a Box to put everything in, but a lot do have the VFD outside
    From your main panel you would have to use a 4 wire cable not 3 as you have suggested using 10/3, you need a 4wire cable to be able to do 120v and 240v from the same supply you need a Neutral and a Ground
    So from the main panel you would wire to a disconnect from the disconnect you would use a 2 Pole Breaker for the 240v and a single Pole Breaker for the 120v supply, these would need to be correctly mounted in a box along with everything else that you can fit in it for your machine
    You mount every thing on a metal plate and this plate is Grounded with a ( star point Stud or Bus ) The metal Plate is called a Ground Plane
    The 240v supply Voltage is wired / connected to the Disconnect Just the 2 Hot wires in your case most Disconnects are 3Pole but you only use 2 of the Poles for switching
    Here is a disconnect and the Breakers you would use they don't have to be the same as this but they will be of a similar type
    Mactec54
  17. #37
    Jan 2017
    31
    In regards to 4 wire cable, I would call it 10/4, but for some reason,Romex calls it 10/3 with ground. It has the four wires. Red, Black, White and bare. I can't blame this on Chinese. But yeah, I know what you meant.
    Thanks.
    Charles
  18. #38
    15362
    Thanks.
    Charles
    Yes of course Romex is fine as long as it is installed correctly, Cable and Romex are to different things, most machines like CNC Routers are installed with a Cable from a wall plug
    Mactec54
  19. #39
    Jan 2017
    31
    A few more questions:
    1. Do I need an EMI filter for the VFD supply?
    2. Which should I use relays or contactors, that are also controlled by my E-stop switch, to turn off the VFD, Cooling pump, Stepper motor controller?
    Thanks,
    Charles
  20. #40
    Jan 2017
    31
    Didn't realize how expensive enclosures could be.
    Saw this steel tool cabinet at a store nearby.
    Its 28" x 28" x 12" for $80.00 Not very dustproof since there are no seals, but that's an easy fix.
    The shelf is removable.
    Would that suffice?
    Thanks,
    Charles
Page 2 of 5 1234
  1. Buying new Chinese ATC spindle.
    By 520052 in forum Chinese Machines
    Last Post: 05-12-2020, 05:42 PM
  2. Buying a VFD Spindle
    By basha318i in forum Spindles / VFD
    Last Post: 04-05-2018, 09:41 PM
  3. Replies: 16
    Last Post: 09-23-2015, 11:54 PM
  4. X3 spindle motor died - Any easy retrofit solutions?
    By pumpercloggs in forum Syil Products
    Last Post: 02-16-2014, 10:25 PM
  5. Replies: 8
    Last Post: 11-21-2013, 06:53 PM
