588,231 active members*
4,258 visitors online*
IndustryArena Forum > CAM Software > Vectric > Z cutting deeper the more time goes by ???
Page 1 of 6 123
Results 1 to 20 of 105
    Sep 2003
    1475
    Vectric VcarvePro 8.5.
    I started a V bit text cutting file and after 1.5 hrs it was cutting very deep. I shut it down and told it to go to Z zero (surface of material) but it went 0.080” below the surface.
    I lifted up on the router and a didn’t see and play between the delrin nut and the acme thread.
    Can you offer some troubleshooting tips.
    HH
    Nov 2005
    222
    Re: Z cutting deeper the more time goes by ???
    Not familiar with that machine but check for pulleys or shaft couplers that may able to slip on the shaft. If mechanically OK, Then I would suspect the Z axis is missing steps. Try slowing the acceleration rate.
    Sep 2003
    1475
    Quote Originally Posted by rcheli View Post
    Thanks,
    Using Mach3 and Vectric VcarvePro 8.5 have ran this homemade CNC as a hobby machine for 10 years and this is the first time I have had this happen.
    I checked the Z stepper connection to flex coupling and flex coupling to Acme shaft, and the acme shaft to the bearing that holds the acme shaft and all were secure.
    Set up a dial indicator on the Z axis and did the following. I ran it hundreds of times and Z always returned to Zero.
    Any suggestions for troubleshooting?
    thanks
    HH
    F15
    X0
    Y0
    Z0
    Z0.5
    F70
    X0.5
    Y0.5
    X0
    Y0
    Z0
    F15
    Z-0.1
    Z0
    Z-0.1
    Z0
    Nov 2005
    222
    I would guess that you lost steps on a rapid Z move in the plus direction (up). If it was commanded to go up 1000 steps but only moved 990 and then it was commanded to go back to zero it would end up 10 step too low.
    Try something similar to what you did with the G-Code except us a rapid move (G0) in the plus Z direction rather than a feed move and see what happens.
    Start with the bit an inch or so above the bed.
    G91 Incremental distance mode
    G0 Z1 rapid up one inch.
    F15 Z-1 Feed back down 1"
    Repeat the last two lines a bunch of times
    Then G91 set to absolute mode
    Then go back to Z0 see where it ends up.
    Sep 2003
    1475
    The Z moves were set to 15, where/how did RApids get in? Are rapids set automatically, where can I find the rapid settings in VcarvePro or MACH3?
    Thanks for your comments
    HH
    Quote Originally Posted by Mr.Chips View Post
    The Z moves were set to 15, where/how did Rapids get in? Are rapids set automatically, where can I find the rapid settings in VcarvePro or MACH3?
    Rapids and acceleration are set in Mach3 ...
    Settings -> Motor Tuning -> select Z axis
    Being 10 years old, the motor magnets may be getting a bit weaker, and the z axis may be a bit tight somewhere so lifting is just on the edge. SO try just halving the speed and acceleration values ... and on this screen you have to remember to hit save as well
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
    35538
    Check the Z axis for binding. Maybe it just needs cleaning and/or lubrication?
    Dec 2003
    1240
    Have you ever changed the acme thread on the Z axis? After ten years of use it must have worn a bit and you would need to check for wear at the height of travel where the loads have been highest.
    Sep 2003
    1475
    Quote Originally Posted by lsces View Post
    Didn’t see a “rapids” figure on that screen, maybe it’s called something else there?
    Motor tuning is a mystery to me I just came up with these settings and didn’t change them for years, maybe they are not what they should
    be.
    Here are my motor tuning settings, IN PER MIN
    VELOCITY .................70.02
    ACCELERATION....... 5
    G’s ..............................0.0129509
    STEP PULSE .............5
    DIR .............................5
    HH
    Sep 2003
    1475
    Gerry,
    here are some photos of the Z axis so you know what i'm working with. guess i cant add photos here so i'll post at the end of this thread.
    thanks
    Sep 2003
    1475
    Here are the photos of the Z axis. this should help in knowing what i'm working with.
    HH
    Sep 2003
    1475
    HH
    The far right photo shows two button head cap screws in the front , They secure the router assembly to the acme thread/nut. I'll support the Z axis and remove the two screws, this will disconnect the Z assembly from the Acme shaft/drive nut. then drive the Z nut to the topmost position then I can move the Z assembly up and down by hand, looking for binding and such.
    We have out of town visitors today so it might be put off till tomorrow.
    Thank you all for your comments and assistance.
    I have extra acme thread, just would have to turn it down to fit the flex coupling, would have to order a ner 1/2' delrin nut, ill plan this for the near future. Probably replace the delrin nut on the X axis at that time. The two Y axis control shafts are 3/4' ball screws. Yes after ten years i need to check out everything, but it has worked super despite my inadiqate knowledge.
    Sep 2003
    1475
    For your information, here's the right side of the 3/4' ball screw Y axis drive.
    Sep 2003
    1475
    Had some free time and disconnected the Z axis assembly (two button head cap screws) from the acme screw and removed the router. The Z assembly moves up and down the two linear rails using four trucks connecting the assembly to the rails. The assembly moved up and down the rails by hand effortlessly, without and binding or tight spots, it is perfect.
    I ran the disconnected nut assembly to the top, middle, and bottom if its travel There wasn't any vertical looseness or free play at any position.
    I am satisfied that there is not an issue with any part of the mechanical parts of the Z axis.
    So where to now?
    I would like to eliminate the TXT file its self. Here is how the TXT file was generated and settings:
    The TXT file started out as printed pages in this case Chinese text, (my wife is Chinese, and this was to be a MDF poster for their up coming womens fellowship) I scanned the pages and saved them as .JPG files. I opened a new file in VcarvePro 8.5 (16x20") and imported the files and converted them to vectors. i then used the "curve fit to vectors" utility to smooth out the lines, i was told this enables the cutter to travel more smoothly. I used 60 degree V bit utility, with settings of: Pas depth 0.050", Feedrate 35 IPM and plunge rate of 5.0 IPM. I recall the run time was 2 hr 45 min. Roughly 2 hours into the cut the Z started cutting deeper, I then stopped the run and checked the Z Zero point and it was 0.080" lower than the surface of the material, when the file started the Zero point was set to the surface of the material.
    In years past I have ran 16x20" MDF cut posters like this without an incident.
    I can attach the file if you would like to look at it and possibly see if possibly there might be code in there that would have caused the problem
    With this information so far does anyone have any suggestions?
    Thank You all for your kind suggestions.
    Apr 2016
    841
    I'm a late comer to the party. I had exactly the same thing happen to me. It turned out to be a slipping flex connection to the screw. I first thought it was a problem with my cut file, but it happened with different files. Rule that out. So, I started looking at the mechanical. I messed with just about everything. It all looked and felt good. I was sure everything was tight, but nothing, other than a loose connection, explained what was going on. A slipping connection to the lead screw made the most sense. I recalled that a couple of years earlier, I tried a product called Vibra-tite as a thread locker vs.the tried and true Locktite. I removed the two cap head fixing screws, cleaned out the gunky Vibra-tite from screws and connector, used blue Locktite and reinstalled the screws. I tightened the screws down so tight I ended up camming out the head on one of the screws. I know it was slippage, because tightening down the screws solved the problem.
    I zero through cuts to the spoilboard and never cut into the spoilboard. One day, I noticed a very shallow cut into the spoilboard, but since I was only a couple of thousands, I didn't think too much about it. Sometimes it would make a light cut into the board, sometimes not. Then, one day I was cutting some wood brackets for my dust collection system and the bit dove deep and caused a mess. I thought it was the cut file, so created a new one and ran it. Same problem, different area on the part. That led me on my quest to track down and fix the problem.
    Gary
    Sep 2003
    1475
    Quote Originally Posted by GME View Post
    Gary
    Thanks for the suggestion Gary but I checked the vertical play of the acme screw when the Z assembly was disconnected from the screw and no vertical play, plus check the second picture I have a bearing below the flex coupling to prevent any vertical movement and both of its locking set screws were tight.
    The mystery continues.
    I’m gonna run the file again in the morning and see what happens. Thinking of rigging up a dial indicator set at the deepest cut so I can know when it happens if it goes deeper than expected.
    Apr 2016
    841
    My issue had nothing to do with vertical play. I believe my problem had to do with what happened when the Z axis went positive. The coupling was slipping in the positive direction, because the weight of the moving parts require more effort to go up than down. You've probably observed this when turning the acme screw with the stepper removed. Easy to screw it down, but much more effort required to turn it in the up direction. Anyway, because the coupling was slipping, it meant that Z wasn't going up as high as the program commanded. Then, when Z was commanded to go negative, it was already too low, so the bit cut too deep. I don't believe your bearing would prevent the same thing from happening to you. If the coupling slips, it just means the router won't go as high as it should. The weight of the router and related parts translates into less effort required to go negative, so coupling slippage has less, if any, influence on how far negative the router travels.
    If your coupling set screws are truly tight enough, I have no other suggestions to offer. I would note that when I was checking things, the coupling was not so loose that I could hold the coupling in one hand and turn the screw with the other. It seemed tight, but clearly wasn't tight enough.
    I wish you the best of luck.
    Gary
    Sep 2003
    1475
    Thanks Gary
    Your reasoning is very sound, after the run I checked, all the Z axis stepper, Coupling, the large bearing and router bit, didn’t find anything loose. I’m going to run the file again this morning and see what happens.
    I’ll post results.
    Nov 2005
    222
    Gary
    I believe the issue is what GME said or you are losing steps. In either case there is lost motion in the up direction. If the set screw push directly on the shaft I would put flat spots on the shafts. Then clean the set screw and hole threads with acetone or some other degreaser then use blue Locktite on them. Once it slips or loses steps the machine does accurately know when the bit is in the Z axis.
    Sep 2003
    1475
    Thank you for your suggestions, I ran the file again and the Z zero point from I originally zeroed at the surface only increased 0.010” in depth.
    What I did between the first run and the second run:
    1. Tightened all the Z axis related set screws, more than I would normally hand tighten, just enough to hear one tick of the S Screw. None of them were moved more than that single tick, none found loose.
    2. Changed the pass depth from 0.050” to 0.100”. Cutting MDF with a 60 degree V bit
    Don’t think the increase in pass depth had and depth effect, just ran the file about 35 minutes faster.
    Summary:
    At this time I’m thinking it was related to the set screws.
    The lathe turned end of the acme rod does have flats as well as the stepper motor.
    However the big flange bearing under the alignment coupler tightens down on the acme rod, no flat spots. I think I should turn the section down and make some flat spots for those set screws to secure to.
    Again thank you all for your input and keep me focused.
    HH
Page 1 of 6 123
  1. LAser cutting machine makes a wave in a corner at the time of cutting
    By angeldp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2017, 03:51 PM
  2. Machine cutting deeper than G code indicates
    By kaetamer in forum Avid CNC
    Last Post: 12-12-2016, 11:30 PM
  3. Z axis cutting deeper than expected
    By bitsa in forum Chinese Machines
    Last Post: 11-08-2015, 08:40 AM
  4. Cutting deeper than flute length
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 12-22-2011, 04:49 AM
  5. Cutting deeper than cutting length
    By magudaman in forum CNC Tooling
    Last Post: 10-10-2011, 04:36 AM
