588,049 active members*
4,111 visitors online*
Results 1 to 11 of 11
    Aug 2005
    6
    Fanuc 6M parameters
    Hi all;
    We bought a 2nd hand Amada punching with Fanuc 6M controller.
    HOW CAN WE GET,SAVE,EDIT THE MACHINE PARAMETERS?
    We do not have any manual but we know the machine parameters
    are very important and we should have a back-up copy of it.please help.
    Thank you in advance.
    S.Bahmanpour(Mr)
    Dec 2003
    24220
    Ready whatever type of upload/download device you have and set the output type to EIA (ASCII) select MODE SELECT switch to EDIT select address PRM input -9999 and push PUNCH button or whatever the button you have for output.
    The list of parameters for 0000 to 0004 are the options and should be recorded by taking them off the Parameter screen.
    They can be re-loaded by hand or by READ in. the small toggle switch on the bottom left of the main circuit board has to be in write posn. select the addrss PRM, input number -9999 via DATA key push the READ button, set read toggle switch on Mainboard back to original position.
    Al.
    Albert E.
    May 2007
    4
    Hi Al,
    Any idea where I can find the Mazak micro turn fith Fanuc 5t parameters?
    Tnx
    KG
    Dec 2003
    24220
    I don't have any 5t parameters, you could try the CNC forum at http://www.practicalmachinist.com
    Someone there may have the same machine.
    Al.
    Albert E.
    Mar 2010
    dear,
    Two years back, wepurchased used kitamura mycenter-2 VMC. with fanuc-6M control
    since we are facing problem after circular interpolations. ie., ovality by 0.3mm.please help me to overcome from this. Please send the PARAMETERS Also.
    paresh j
    May 2007
    42
    Hi Paresh,
    You can adjust by potentiometer on servo amplifier.
    Refer attached file please.
    Good luck!
    Mar 2005
    816
    I have an anciemt Amada Pega with the FANUC control. I will see if I still have its parameters.
    I remember that the Amada sales guy came out and got it set up..
    Greg
    Aug 2011
    14
    Re: Fanuc 6M parameters
    Al.
    Hi just wondering, this punches out all of our parameters up to line N0179 that's around page 9, there seems to be a lot more lines it does not take, Parameter seems to be 24 pages long and has some number going up to N4000.
    Is this correct it only take the first 179 lines. Control is a fanuc 6m
    Macca
    Dec 2003
    24220
    It has been 20yrs since I worked on a 6M.
    That is all I have or can remember.
    Al.
    Albert E.
    Mar 2017
    314
    If you have RS232 communication, you set that up through 340 341 and 310~320ish right
    if it is bombing out early I would suspect a communication problem
    It wont punch timers keep relays and pc parameters.
    pS , photograph every page. more data never hurts
    Mar 2009
    101
    I generally set 340=3 341=3 that tells 6M look at param 312 I set 312=00011010 2 stop bits & 9600 baud.
    On set page( if uploading param to laptop)
    punch code 1=
    input device=1
    input device 2=1
    You can not change set page if you are downloading to the control after a memory clear. Need to load 0-8 parameters by hand then you can change the set page and ready for transfer.
    edit mode
    program protect off
    param page
    type -9999
    press read or punch depending on what u are doing
    All NC parameters will upload. Not PC parameters
    You can not up or down load PC parameters. They stored under diagnostic screen.
    You can only type by hand
  1. Parameters FANUC O-L
    By nsdjole in forum Fanuc
    Last Post: 04-25-2022, 05:29 PM
  2. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  3. fanuc 11t parameters
    By aguilar in forum Community Club House
    Last Post: 06-26-2013, 07:40 PM
  4. Parameters for YAM CK-5, Fanuc 10T
    By gisab in forum MetalWork Discussion
    Last Post: 12-07-2009, 09:39 AM
  5. Fanuc 0T G83, G84 parameters
    By davisboys in forum Fanuc
    Last Post: 03-18-2007, 05:29 AM
