587,523 active members*
3,753 visitors online*
Results 1 to 9 of 9
    Apr 2019
    32
    How do i move the spindle with mach3?
    OK, I thought I could work this one out myself but nope.
    I installed mach 3 (but haven't bought it yet), I ignored the disk that come with the machine as I have nothing to read it.
    Turned on the controller box.
    I plugged the parallel to usb cord into computer (Microsoft surface book). It was identified.
    Opened mach 3.
    NOW WHAT? I cannot see any evidence that the computer is communicating with the steppers/spindle at all. Do I have to install drivers? What can I do to test this?
    Apr 2019
    10
    Re: How do i move the spindle with mach3?
    Not sure if it helps but the DVD/CD that came with my CNC also included a config file that needed to be added to a folder in Mach3 (along with the good old pirate mach3 that everyone should ignore). I would hit up the reseller and see if they can provide that file digitally .
    PS, if you are very new to Mach3 please also note that the reset Button is activated by Default (the Stop switch on the machine may be as well) so make sure those are also both off. If they are off then you should be able to move the machine with the arrow keys. (Get a Xbox 360 controller , makes life a lot easier, just make sure to read the setup guys as there are several setting that need to be changed before it will work as well).
    Apr 2005
    305
    It wont work with usb/parallel converter.
    Give more detail on your machine's electronics.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Apr 2019
    32
    I hit the reset button, made sure the emergency stop button was turned (doesnt seem to do anything anyway). I cant get it to move.
    The parallel to usb cord came with the machine. I've attached pic of machine.
    This is the message in the computer control panel for the controller box;
    "The drivers for this device are not installed. (Code 28)
    There are no compatible drivers for this device.
    To find a driver for this device, click Update Driver."
    35538
    You need to install a plugin that allows your USB device to communicate with Mach3.
    Apr 2019
    32
    I tried pasting the RNRMotion.dll into the plugin folder but pfft "rnr motion card not found!". I hate this thing and I want to smash it. I guess I'll try and find an ancient computer with a parralel port.
    I went to my neighbours and used their relic with a disk reader to copy the files onto a usb stick, it had the program "CNC USB" on it, but that doesn't work either.
    I'd love to take the computer out of the equation, can I purchase one of those controllers with the SD reader and have it plug and play with the machine I've got?
    Apr 2019
    32
    I got it to move by installing the evaluation version of CNC USB, hacked version on disk didn't work. Still interested in getting mach3 to function via usb.
    15362
    Quote Originally Posted by htraps View Post
    It's not possible without the USB Plugin correctly installed that's what the supplied thumb drive would of had on it plus all the configuration files
    Mactec54
    Apr 2019
    10
    Have you asked the reseller ? They may have an updated copy/ Not corrupt copy of the drives / config file. While normally useless for hard trouble shooting they can often get that far at least.
    Also what version of windows are you running? (i'm assuming a Surface Book is Win10) I have never personally tried it but I hear that mach3 is not a huge fan of the newer version of windows (i run Win7 personally and its fine).
  1. Need a way to tell Mach3 to move -20mm in x and _60mm in Y
    By AllenMassey in forum Mach Wizards, Macros, & Addons
    Last Post: 03-31-2016, 03:48 AM
  2. Can Mach3 move 2 axis at same time?
    By davidlee64 in forum Mach Mill
    Last Post: 05-31-2015, 05:51 PM
  3. CNC router 6040 from Ebay - can get MACH3 to move from the computer
    By tvheadclothing in forum Chinese Machines
    Last Post: 05-14-2015, 04:15 AM
  4. g540 w/ Mach3, Can't get motors to move.
    By speeddemon974 in forum Gecko Drives
    Last Post: 10-27-2011, 02:18 PM
  5. Anyone had Mach3 gain .001 per .100 move?
    By superchargerjim in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2011, 02:36 AM
