587,547 active members*
3,420 visitors online*
Results 1 to 2 of 2
    Tool parameters restore problem (MAZAK 15MS-Y)
    Hello, please help! The problem is that the old machine MAZAK SQT 15MS-Y(Mazatrol T plus system) erased the parameters on the SRAM board. CNC system - Mitsubishi FCA535LHY. I have restored parameters manually from the list on paper. The machine turned on goes to the zero position on all axes, there are no errors. But when the turret rotates, the tool number does not change. He is always constantly T0. In MDI mode, the turret does not rotate on a tool call command. How can I write to the memory of the machine T1 in the first position of the turret? Please help in this problem.
    Sep 2017
    139
    Re: Tool parameters restore problem (MAZAK 15MS-Y)
    You would have to delete the complete tool data and insert once again manually. This can happen if the tool dat is corrupted
  1. MAZAK FH6800's Parameters for Tool Lenght measurement system
    By sonu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-28-2022, 11:11 AM
  2. Postprocessor Mazak sqt 15ms
    By Tutan in forum FeatureCAM CAD/CAM
    Last Post: 01-30-2013, 02:02 AM
  3. Mazak sqt 15MS postprocessor
    By Tutan in forum Post Processor Files
    Last Post: 01-26-2013, 10:12 AM
  4. Restore Problem
    By sodfarmer in forum Autodesk
    Last Post: 04-19-2012, 12:19 AM
  5. restore parameters
    By crousow in forum Fanuc
    Last Post: 03-08-2009, 10:44 PM
