Re: Problem with cranking up the current for steppers
Originally Posted by
tangi
Ok so I should try to switch PSU to maybe a 36V? This is what info I have about the motors
https://ibb.co/7CycQ6r
I guess I am not smart enough to figure the voltage out but if your limiting the amps I don't see how it could damage the motors using a 36 volts. But you need to look at the amp rating of the PS and get one designed for CNC work. It may be a DC power supply but your stepper drivers are outputting pulses. Here is a screen shot of a stepper motor being operated at different voltages. FYI.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
