In the NA they don't have a Neutral for 240v single phase they have 2 Hot wires each being 120v they are 180 degrees out of phase, ( so to make this very simple ) each hot takes turns at being neutral, so this works out to be the same as yours except you have ( 1 ) Hot wire and a Neutral and a Ground for a piece of equipment like this, this machine is missing the Ground part which it needs before it is put into service the Hot wire part is fine you just connect the ( 2 ) input terminals L1 and N with the 2 Hot wires used in NA ( North America )
