Hi everyone !
I have bought a Workbee CNC machine from the company Ooznest and I'm trying to calibrate the machine.
I'm using Fusion 360 and it seems that I have a toolpath issue but I don’t know if it’s a machine issue or a software one but all of my outliner cut are correct but not the one which go in.
So i have drawn a square of 62 by 62mm with a notch of 18mm (please see attached picture 1-1 & 1-2).
To make this work, I have mounted on the CNC a flat 1/4 inch end mill from your starter kit (please see attached picture 5-1 & 5-2).
On fusion 360, I have set up some parameters to do the job ( please see attached picture 2-1 until 4).
By the end, after doing the first test, I have got :
x=62,76 mm instead of 62 (picture 6-1)
y=62,49 mm instead of 62 (picture 6-2)
notch= 17,18 instead of 18 (picture 6-3)
I have watched the ooznest video about how to calibrate the workbee, I have done it 3 times to have a precise cut ( picture 7).
Link : https://www.youtube.com/watch?v=PsCiCDZeuek
After doing the last cut, I have got :
x=62,00 mm instead of 62 (picture 8-1)
y=61,98 mm instead of 62 (picture 8-2)
notch= 17,12 instead of 18 (picture 6-3)
I don’t understand why my outliner cut are correct and not my interline cut, it doesn’t make sens to me.
To give you more details, I have downloaded your small program for fusion and to export the gcode.
Hope you have enough element to find out my problem and tell me what’s going on and hopefully give me a solution.
You will see the rest of the image on the next post.
Thank you all in advance
