Originally Posted by
ger21
They are actually very repeatable, as repeatability is somewhat independent of accuracy.
Because repeatability is rather easy to attain, as is flatness, for most people, the only requirement is to get it square, which can easily be done by making some test cuts.
You may be surprised how easy it is to get a machine that's remarkably accurate and consistent. If you need ultra high precision parts, that all need to fit together very well, than a router is probably not the right tool for you. If you need everything to always be within .005" or less, it get's a lot more complicated.
