587,481 active members*
3,269 visitors online*
Results 1 to 8 of 8
    Mar 2006
    42
    Amada Fanuc 0L problem laser
    Ok I have the above mentioned laser and when powered up all seems to be fine no errors at all
    to home machine just push cycle start (runs program # 7900 and supposed to home
    Cycle start does nothing no errors no saftey device alarms nothing!
    just no homing.
    anyone have any ideas?
    Mar 2006
    42
    If it makes anyone feel any better it has so far stumped the Amada techs also
    Nov 2004
    53
    Having worked on Fanuc's for 20 years or so, if I were the tech's from Amada I would be ashamed of myself.
    That problem should have taken no more than 1 hour to come to a conclusion.
    I have written a lot of ladders for 0 series control and only a few things can stop the machine from moving when the subroutine for homing is called up.
    I am not familiar with Amada however I can tell you there is nothing I can't diagnose on that control within an hour.
    I see this all the time from factory tech's from (mtb) and some of them are lucky to find a customers plant without GPS let alone fix something without a dozen phone calls to the office.
    OK so maybe I exagerated it may take me 2 hours.
    Good Luck........if you can display the ladder and can give more details I can probably steer you in the right direction.
    Good Luck if you are around the Los Angeles area call me
    714-334-4261
    Nov 2004
    53
    Display your ladder and search for G120.2 this is the cycle start signal
    all the variables on that rung must be high to get a proper cycle start.
    You will see what is holding you off.
    You should see it turn off and on with the button
    Good Luck
    Question Amada
    I know I can't help you with your problem sorry, but by chance you may be able to help me if your wattage is the same. The company that I am programming their laser is having trouble cutting 3/16 and 1/4 steel and I think it is more of a machine than program problem. If your laser is a 1500 or 2000 watt could you share the G65 P9100 like the example below with the setting you use for 3/16 and ¼ material.
    G65 P9100 S1500 H90 B100 C20 I63 J0.1 W1000 Q90 T100 U0 I63 J0.0
    Independent CNC Programmer
    www.ctcn,net/~3kings/
    Mar 2006
    42
    I do not use an H or a Q ?
    AT APR. 50 IPM (might get away with up to 65 or 70) CUT SPEED & 1.0 kgf/cm2 This is what I would try.
    G65 P9100 S1500 B80 C25 I63 J2.0 W1500 T1000 U35 I63 J.5
    Biggest thing i see is your U of 0 is giving you no duty cycle? And only using 1000 Watts for cutting? MUST have the 2.0 in the first J this is the time for piercing
    Hope this helps. please let me know?
    Mar 2006
    42
    Thanks all Amada problem is fixed
    Debco99 your help was perfect it was a safty mat problem
    Nov 2004
    53
    Great, glad it worked out.
    Regards
