Those grease nipples are a bit of a laugh too. How do you expect to get a grease gun on the Z nut when it's fitted???. You want some elbow fittings and 4mm tubing so you can put the grease nipples on the outside of the machine. Grease then flows from the nipple, through the tube, into the nut.
Unless you're doing a one shot oil system.[/QUOTE]
dazp1976,
i was thinking the same thing where did you buy your elbow fittings? you have a part numbers?
