I didn't check my ballscrew lengths, only tested the ends to make sure they fit the bearings and preload nuts correctly. I'm just starting to machine the conversion parts now.
If Z or Y are too long, I figure I could cut/grind them down.
X- I can make my motor standoff a little taller.
I'm taking a shortcut with the motor standoffs to save a lot of time since I'm doing all the cutting manually.
I ordered these for the x and y mounts, they are a little tall, so I should just need to cut them down to the proper height.
https://www.amazon.com/RATTMMOTOR-St...gateway&sr=8-6
I ordered a Nema34 mount as well, but its design is different (hollow) and I thought I would have to do significant modifications to get it to work, so I sent it back. Turning the standoffs on a lathe would be a lot easier in this case.
